Question about Kenwood KDC-MP228 CD Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
I purchased above radio, I bought a harness to plug to stock plugs, then wired to radio. Radio comes on, but no sound at all is coming out, did I get wrong harness?, or cross something? Is there something I need to do to set radio up? I disabled display mode, I think I cleared code lock, Im at a loss. Thanks for any help
  • Anonymous Dec 26, 2008
    Same radio, different vechicle. Bought the correct harness; matches colors and old diagram on old radio just fine. All functions on the MP238 seem to work but there is no sound at all; am/fm or CD source.
  • 3 Answers
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Posted on Nov 15, 2008
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
I need a factory speaker and radio wiring diagram for a 2009 dodge 2500 quad cab truck
This is what my books show.
2009 Dodge Ram 2500 Car Radio Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Amp Trigger Wire: Dark Green/Red
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 12, 2012 | Cars & Trucks
Trying to install and rewire the kenwood KDC-MP149 cd player into my 1997 lancer. having problems matching up the wire colours thanks
I recommend you purchase a wiring harness. This will make the install much easier. You can match up the wires of the radio and the harness with ease (since all aftermarket radios have standardized color coding for the wires). You vehicle wires will never match the radio, unless it's stock. You can purchase one at www.crutchfield.com Hope this helps.
Aug 25, 2011 | Car Audio & Video
I am installing a new cd player in my 2006 dodge ram single cab truck, i have made the mistake of the cutting the stock wiring harness plug. Now i need to know what color codes are on these wires so i can...
Hello my name is Israel. I have added the following informaiton to help you out. Good Luck.
Radio 12v gray/red + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/yellow + radio harness
Radio Illumination orange/tan (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. grn/yel - dk. grn/lt. blue +,- radio harness or amplifier
Notes: The amplifier is behind the glove box.
RF Speaker +/- gray/yellow - gray/lt. blue +,- radio harness or amplifier
LR Speaker +/- gray/lt. grn - gray/dk. grn +,- radio harness or amplifier
RR Speaker +/- dk. grn/lt. grn - dk. grn/gray +,- radio harness or amplifier
Feb 21, 2011 | 2006 Dodge Ram 1500
I have a 98 dodge ram 2500 I installed a aftermarket radio and have power but no sound please help
Sounds like you hooked the wires up wrong. Crutchfeild.com sells the direct plugs that go from the deck to the stock wiring harness. Its a good investment. But check your wires.
Jan 17, 2011 | 1998 Dodge Ram 1500 4WD
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP228 CD Player
Kenwood KDC-MP228 CD Player Logo
589 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
