Question about ViewSonic VG900b (Black) (10 Pack) Monitor
Viewsonic VG 900 displays briefly, then goes blank
Exactly what was said in the subject. The monitor turns on, shows the image for a few seconds, then goes black. Testing with another monitor, the problem is not in my video card or cable. Thanks for any help you can provide.
  • Hoovooloo Oct 12, 2008
    Thank you both for your comments. To answer jjcf89, it happens every time I turn it on (thought the time it is displaying something seems to vary a bit), the monitor has worked before, and I got it from a friend after it broke so I don't know how old it is of how it broke. To bammbammfran, I currently have it taken apart, and have a DC tester. Where should I check/what are good values? Again, thank you.
  • Jonathan May 11, 2010
    Does this happen every time you turn the monitor on? For example, you turn the monitor on and you see your desktop for about 3 seconds then it just goes blank. You turn the monitor off and back on and it repeats. Has the monitor ever worked before? Is it brand new or have you had it for a while?
  • 159 Answers
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
Posted on Oct 11, 2008
  • Fran Bednar
    Fran Bednar Oct 12, 2008
    Can you get me a picture of your board since it is apart.
    IF not, Do any of the canister looking components(capacitors) look bulged at the tops.
    One place that you can check for dc voltage is at these canisters (the
    side of the canister that has the stripe is the negative side- It may
    also be marked on the board right where they mount)
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
VG 181 displays page then goes blank
Look to see if you do have 12~18vdc feeding the backlight inverter board (located on the left side of the monitor), it can also have blown fuses on the inverter board. Post back what you see inside so we can guide you further, this is really old monitor, 2002.
Feb 15, 2010 | ViewSonic VG181b 18.1" LCD Monitor
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
I have a VX1962WM monitor. When I power up my PC I can see an image briefly then the screen goes black. When I power the monitor down and back up I again see an image briefly and then it is gone. I have...
That's right, the problem is related to inverter, but source of it - backlight lamps (if you see an image for fractions of seconds) or MOSFETs (if you see an image for few or more seconds). Image shows up, that means inverter starts, but then goes off because inverter controller turns into protection caused by something. Checking lamps is not that hard. Disconnect all cables coming from the screen and remove chassis with PCBs, so you will keep the display itself only. Next, at the edge where high-voltage wires are coming from, there you will see tiny philips screws, take them off. Then gently and very straight pull lamps assembly off the display, one and then another. If lamp is bad you shall observe contrast black ring or black dots near to the electrodes. Bad lamps must be replaced, you can buy them on ebay, for instance, just search CCFL 19". Or, if you don't care about total brightness, you can substitute faulty lamp with 27 pF 3kV capacitor, soldered across appropriate HV-connector on the inverter board - this will work also.
Sep 14, 2009 | ViewSonic VX1962wm LCD Monitor
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at
Mar 02, 2009 | ViewSonic E70f 17" CRT Monitor
Optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
ViewSonic VG900b (Black) (10 Pack) Monitor Logo
342 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
