Washer will not shift into the spin/drain mode. Aggetator works fine.
  • kerryklein Oct 11, 2008
    This is for Kenmore Series 90 washer
    The lid switch is broken. I will replace. Thanks much,
  • 5,911 Answers
If your washer stops when it gets to the spin cycle, this is usually a symptom of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, It must be replaced. Please post back and let me know if you require replacement parts. This is not an expensive repair. On average, a new switch runs about $25 - $35. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
I hope you find this information helpful. If you require additional assistance, please let me know.
Posted on Oct 11, 2008
    President:
  • 2,712 Answers
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Oct 11, 2008
      Genius:
    • 1,847 Answers
    If its not spinning or draining maby the motor is to shot to to handle it any more. Again I would not know as I work with small engines.Is the wig wag controlled by a motor or belt. maby thats bad.
    My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
    Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
    Jul 04, 2016 | Maytag Washing Machines
    Washer stuck in drain and spin mode
    Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
    Sep 15, 2015 | Kenmore Washing Machines
    Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
    i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
    Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
    I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkout this tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Dec 12, 2010 | Washing Machines
    Washer will not drain
    By lifting the lid you are performing the job of the timer. In your unit you have a neutral drain transmission and the timer is programmed to end the washing cycle by stopping the motor. When it starts back up, it reverses and the transmission is in the neutral state. The water drains and after about 3-4 minutes, the timer is suppose to disconnect power to the motor thus stopping the transmission inducing the transmission to shift into spin. When it starts back up, it spins. So when you lift the lid, you pause the motor and the transmission shifts. Close it and it spins. Replace the timer and you will be fine. If I can help further.....
    Waiting to hear from you,
    Eric Campion
    Feb 13, 2009 | Washing Machines
    Washer wont spin or drain
    did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
    Feb 07, 2009 | Frigidaire Washing Machines
    Fisher Paykel GWL10US won't spin
    hi
    if the pump works fine in diagnostic mode then it has tobe a module problem
    cheers grant
    Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Richard Roth
    Richard Roth
