Philips model 37pf9431d/37 no picture
On philips model 37pf9431d/37 no picture. Red led is blinking once, then twice.
  • 4 more comments
  • chavargas Oct 11, 2008
    on philips model 37pf9431d/37 no picture. Red led is blinking once, then twice.
    when the TV was ON suddenly turn OFF without touch in anything.
  • chavargas Oct 12, 2008
    Sergeant:
  • 352 Answers
Check out this site hundreds of owners of your model discussing every imaginable problem. Its actually pretty cool. You may find your answer, or be led to it from here. I'd want to know about this site if I owned this tv.
http://www.avsforum.com/avs-vb/archive/index.php/t-570242-p-2.html
anaanymous
Posted on Oct 12, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, This seems to be complicated. Best would be to get it fixed by Philips itself.
Posted on Oct 11, 2008
    Sergeant:
  • 399 Answers
It happens due to high voltage passed at that time when you were watching the TV .its normal this same problem is faced by many clients and because of this high voltage sometimes the mini tubelight like object on the main board gets blown off, it is called FUSE.you can easily locate it on the main board and replaceit and it is not very costly.you can get this fuse at local electronics shop or at
www.radioshack.com
and the other problem is due to high voltage the extra current passes in the circuit board.that is more then what is required.so the soldering joints on the tracks gets short circuit and the tv goes off.it also happens due to moisture collected on the board and gets short circuit.you can try to repair it if you know how to use multimeters and soldering irons properly.
or the final option call the technician the most safe option.as he will be having all the required parts to exchange.and he will be having all the proper instruments and tools for reparing.and you will also get a garranty of parts which he replaces.it will be negligible as per my knowledge.
thanks.
    President:
  • 2,712 Answers
There is a short circuit somewhere in the power module that is causing the protection circuit to take over the power management. It could be something as simple as a broken solder (unusual these days, or something more complex)
I wouldn't recommend doing a DIY if you've never done this sort of thing before, as there are voltages inside a TV that can KILL. Its always best to call a repairman. At least now you know what to look for..
  • 10,594 Answers
Seems back light inverter board fried and need to be replaced.
  • Shahid Electronics
    Shahid Electronics Oct 11, 2008
    in my opinion, following parts seems defective. You need to call TV Tech Person to rectify and replace board.
  • 1,879 Answers
Anything special happened prior to this state ?
    Genius:
  • 1,847 Answers
The protection circuit has detected a high enough current draw from some section of the tv that it has shut the set down completely. You might get it started again by pulling the power cord for 3 or 4 hours, but it will likely shut down again.
It means there is a defective section; there are many possibilities and only a tech who knows how to get inside and check the various sections can find out for sure.
The most common is the high voltage section; it is the section that draws the highest power in the set. But, it could be the deflection amplifiers, audio amplifier or main power supply sections, etc.
  • 19,396 Answers
Try first unplugging it for half an hour, see if it restarts.
  • Ginko
    Ginko Oct 11, 2008
    I think that is power supply switched off by hardware protection.
    There is probably a problem with an internal part and tv had been switched in standby.
    See if unplugging power works.
    If not the tv must be tested to find the fault.
    If you decide to call a technician, or if the tv is under warranty, you can ring the number listed on the owner manual. I think Philips also sells extended guaranty, give them a call.
  • K Damico Jan 08, 2013
    test
No picture on Philips Model # 50PF7321D/37
The LED normally blinks--indicates the digital/main board is powered up.
Look for other fuses----Boards for these are rather expensive, maybe too expensive.
Google the model number with the word boards or parts after it to research it.
Mar 14, 2012 | Philips Televison & Video
I have a Phillips TV model 37PF9431D 37. The power will not come on and there is a red light that flashes once then twice. Any ideas of how to fix? Thanks.
U have tools,understand basic electronic and can u do basic soldering?Yes,than take the tv aparts,check the tv power supply board,that the board,where the power a/c cord plug into it.Check for those parts call capcitors,these capacitors are dying soon will be dead.These capacitors on power supply board alway bulges or puffing up on it tops.Thess capacitors are dying going to be dead,must be replaced will solved the tv power LED light flashing.Tv will have stable power again and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a hole refurbish power supply board for the replacement.
Nov 17, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips lcd 37pf9431d/37
finally got some help from customer service ----
the code flashing one then two red lights is for an upgrade of the software ---- you can go to their website and download a current fix to that problem onto a thumb drive----
\the power problem is caused by a bad power board--- you can replace them for any where from 130-330.00
dont need a service tech - take off cover and easy to replace---can find part on parts store.com for philips televisions --- used is about 130 and new about 330 -- used is a refurbished unit and works just as good as the new one
Feb 18, 2009 | Philips 37 in. LCD TV
TV does not turn on, blinking red LED
Problem is a bad audio IC esp if your are reciving 11 blink code
if it is a 5 blink code replace Crystal 1h00 On Ssb new part number is 24225430 1397
Jan 12, 2009 | Philips 42PF7321 42 in. Plasma HDTV
Problem
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF9431D/37 No Picture
While I can't tell you what this particular code means I know from experience that power boards fail frequently commonly on those TVs. Do you hear a clicking of the power supply first on and then off after a few seconds?
There's a guy or a company on eBay that offers trade-in for faulty power supplys, you should check them out:
http://stores.shop.ebay.com/TechFetch
Search for 37'' Philips in the title or contact them to ask about it. Used to be $99 flat including return shipping.
Nov 20, 2008 | Televison & Video
Did you check the diodes on the solder side of the power supply?
Aug 29, 2008 | Televison & Video
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
I had the same thing - one long red flash followed by four short red flashes. Plugging and unplugging the power cord had no affect until I also unplugged all the cabled connections to the VCR and DVD player as well. Also, per the manufacturer's instructions, I unplugged the power cord from the surge protector and plugged it into the main wall outlet (which I tried first, but did not finally have success until I cycled the power cord unplugging process with all the cabled connections to the auxilliary devices unplugged as well).
Nov 18, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
