Question about ASUS P5LD2-VM Motherboard
Cd and dvd driver
Some kinds of cd can not be opened by cd driver although they are opened by another computers
Jhjhj
Posted on Oct 17, 2008
    Genius:
  • 1,124 Answers
Go the the Asus website and get your software and drivers there.
Posted on Oct 12, 2008
I have CDR320E Combo.For the past 10days the tray is not opening. And also tried by inserting a small pin in the hole provided at the bottom side of the tray. But still not opening. Now what to do? Shall i...
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
hope this helps you
Nov 18, 2011 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
I don't have the cd for this hardware and I would like to install the hardware in my computer.
you should'nt need any cd to install a cd/dvd othen than a motherboard disk although it should activate the found new hardware wizard once its connected to your computer or you might have to install it manually if you are having problems with your cd rw
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
Jul 14, 2011 | Acer CRW 4406EU CD-RW Burner
Around track 8 in its recording process it breaks up the audio signal so when we duplicate it kick out a error then kicks out the CD's
this could be caued by a few possibilities you might not have select to burn an audio copy or the burning software does not support the burning of audio copies although if it burns a few before being interrupted it probably will support audio burning
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
the other possible reason might be the cd/dvd burner is not getting continuos power during the burn process
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Jul 06, 2011 | MicroBoards CopyWriter Live (CWL6200)...
Dear sirs, I have been using an LG Portable Super Multi Drive GP08NU20 but suddenly my portable HP Mini 1000 (with OS Windows XP) is not recognizing it. When I go to "My PC" is not even...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 17, 2010 | LG GP08NU20 DVD±RW Burner
MY DVD WRITER OPENS BUT WHEN I BURN A DVD FROM NERO IT HANGS.... PLS KINDLY HELP ME ... THANKS
hope this helps
Dec 15, 2010 | LG (DAD-8020B) DVD-RAM Burner
I have loaded windows xp on my compaq presario 2100 notebook pc. the toshiba SD-R2312 CD-RW/DVD ROM is not getting detected due to driver not being there. kindly send drivers file by mail.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 05, 2010 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
The cd drive isn't recognized. it was working fine but now it powers up and i can open tray but wen i try to use it the display says no cd drive. i tried another cd writer in it but same prob. help[!!
does it show up in the my computer? what OS you useing i.e XP / VISTA?
sounds like the drivers are missing.What kind of CD you putting in CD or DVD if it's a DVD try a CD & if it plays then the DVD heads have gone it's common for the DVD heads to go before the CD heads.
Sep 28, 2010 | Computers & Internet
LG Combo device read only cdRAM..
Reinstall/update the drivers for combo drive will solve your problem.
Dec 04, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Cd/dvd driver can't read Cd and some DVD
Im having the same problem with my acer. although i can play all cds, just not some dvds. Ive already had a suggestion, heres the link.
Apr 10, 2009 | Computers & Internet
ASUS P5LD2-VM Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
