Gibson washer won't drain
Hi, I have ba Gibson GWX435RBD4 washer.
Stops at the spin cycle and turns off.
It will not drain.
Pushed screwdiver on latch so saw it will spin but not drain.
did see in end little bubbles sort of.
Took front off, and don't see a filter.
I see a square ( housing ) with 2 hoses attached, one coming from tub, other going to drain.
Would like to know the next steps, or what advice you have please.
Appreciate it,
thank you
  • memk Oct 11, 2008
    ps drained the hoses, so water is out
    how to tell what the problem is please
    again thank you for the advice
  • 3 Answers
SOURCE: Maytag Neptune mlg2000aww
SOUNDS LIKE SOMETHING STUCK IN PUMP
Posted on Oct 24, 2007
textonor
  • 130 Answers
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Posted on Jan 23, 2008
  • 52 Answers
SOURCE: Washer won't spin or drain
The problem is most likely the lid switch assembly. The lid switch is a safety feature that will **t allow the washer to go into the spin cycle unless the lid is shut (so ** wandering children get caught inside).
If the switch is working, you should hear a click when the door closes and makes contact with it. If the lid switch is defective/broken, the washing machine usually won't drain or spin. If it's bad, you will need to replace it. It should be mounted inside of the cabinet, just under the door of the washer (on most models). Please let me k**w if this corrects your problem.
Posted on Mar 10, 2008
SOURCE: Gibson front load washer will not spin
Well it turns out that the machine will stiil not spin with water in it. After putting the pump back in (after finding the nickel in it), the machine went into the spin (with all water drained from the basket from my taking out the pump). To confirm that it would spin I put it into a full wash cycle. At the end it would not spin and all water remained in the basket with the clothes. I'm wondering now if it will not spin because the water is not being pumped out and it is not being pumped out because the pump impeller was damaged by the nickel and therefore the pump needs to be replaced?
Posted on Mar 28, 2008
mikedurland
  • 481 Answers
SOURCE: fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Posted on Jun 27, 2008
Ho to ajust air handler blower speed on a Gibson airhandler GB5VM
The Gibson GB5VM's ECM variable speed motor includes 12 field-selectable cooling airflows and 4 heating airflows to match any application. This Gibson air handler's quiet blower operation is achieved through extra quiet and smooth blower on and off cycles. Consult with your INSTALLATION & OPERATING MANUAL provided from your local Gibson Installation Team. If you cannot locate one, you can call GIBSON 24/7 at toll free 888-701-5040
Aug 31, 2014 | Heating & Cooling
Gibson washer gtf 1040 cso vibrates
Hello
Miachael
The problem to your device is not related to my expertise. Please get helped from any other. OK.
Dec 05, 2011 | Gibson Music
Our gibson washing machine stops filling water from cold valve and when we turned the knob to warm, it fill normal for washing cycle, but it does not fill for spin cycle.. Is this because of defective...
check the cold fill hose screen for silt or dirt. also check at water valve for the same and clean. you must have at least 20psi of water pressure for the water to come in. also on most washers cold water is used for rinsing.
Feb 09, 2011 | Washing Machines
Clothes still have water after spin cycle
gibson washer cloths spin . but i think it's spins to slow cloths are still wet
Feb 10, 2010 | Kenmore Washing Machines
Will not drain on spin cycle
Will take to local repair man
Oct 05, 2009 | Electrolux Washing Machines
WASHING MACHINE WORKS UP TO DRAIN/SPIN CYCLE AND STOPS
Hi, this is just a faulty timer control module. you will need to replace this failed control device asap. you can purchase it on line if you choose below by clicking on the link provided.
CLICK HERE
May 25, 2009 | Washing Machines
Fixn my GE washer spin cycle
Jun 27, 2008 | GE WHRE5260E Top Load Washer
well lol thats what i was going to tell you to do if you didnt hear the crunching sound with the power off but good for you
Mar 28, 2008 | Washing Machines
Dishwasher won't drain
I'm having this same problem! Any luck solving it?
Nov 19, 2006 | Gibson 24 in. MDB632XF Built-in Dishwasher
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
