Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
How do I find or change the password so I can allow a laptop to access network
    Genius:
  • 1,913 Answers
Pls finf the reset botton of in back side of your router.then press it for 10 seconds then i\t reset to defaults.
then go to your internet browaser go to ytthis link
http://192.168.1.1
then type usename and pasword both as "admin"
then if not successs then put user name as blank and password as "admin"
Posted on Oct 11, 2008
How do i change the password so people can't connect other than me?
The category is listed as Network and Wireless Adapters, but the question is leading to an answer regarding routers. The router in a network is what allows connection and assigns IP addresses. The router uses encryption and a security passkey (password) to allow uses to connect. You would need to log into the router using the administrator ID and password, go to the Wireless page and change the access password. ALL USERS would then need to reconnect using the new password.
Oct 30, 2015 | NetGear Computers & Internet
Tip
Allowing Network Access with Blank Passwords with Vista
Although you can log in locally without a password, by default, Vista does not allow network users to access the computer without a password.
To change this setting:
Run gpedit.msc
Go to Computer Configuration / Windows Settings / Security Settings / Local Policies / Security Options
Double click on Accounts: Limit local account use of blank passwords to console login only
Disable this option
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Need new password
Which opetaing system and is the password to log on to your computer or an internet connection password ?
How to change your windows password using the command line
http://www.askstudent.com/hacking/how-to-change-your-windows-password-using-the-command-line/
Change a Network Password
A network password is a combination of alphanumeric characters that users must enter in order to access a local area network.
Wireless routers use this password to protect the network from unauthorized users who could potentially steal bandwidth from the network, access sensitive data and view the information being sent to and from the network's router.
To change your network password, you must log on to the router's URL and access its security settings.
Type the router's URL into your web browser.
To access and change any settings on your router, you must log in to the router's URL.
This will allow your computer to communicate with the router and access the router's main page. When accessing the router's URL, use the same computer that was used to install the router.
If you do not know the router's URL, look for this information in the router's manual or on the manufacturer's website.
After entering the URL into the web browser's address bar, press "Enter" or click the "Go" button on the browser.
Input the router's default username and password.
Once you enter the router's URL into your web browser, a dialog box will appear requiring you to input the router's username and password. (Note that this password is not the network password.)
Unless you have previously changed the router's username and password, input the defaults.
Many routers have the default username of "admin" and have the password set as "password" or have no password at all.
To find out your router's default username and password, check the documentation that came with your router or check the manufacturer's website. Click "OK" to proceed to the router's main page.
Access the router's security settings.
Depending on your brand of router, there will be tabs or links on the router's main page.
One of these will contain the page for changing your security settings.
Find and click the link or tab.
This page will contain several textboxes, one of which will contain the SSID (name of the network) and two textboxes for changing the network password.
Select an encryption type and change the network password.
Most new routers offer WEP (Wired Equivalency Privacy) security or WPA security.
Select the type of security and change the network password by typing in a new password in the two text boxes.
When you are finished, click "OK."
Save your changes and log out.
After changing the network password, you must click "Save" or "Apply" to keep the password change.
Log out of the router by clicking the "Logout" or "Exit" link on the router's main page.
If you leave the main page open for a certain period of time, you may be logged out automatically.
Mar 25, 2014 | Computers & Internet
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    How can I ban everyone except me from going to the Belkin info page and getting the password? One of my kids has been banned from the computer but I can't seem to keep him from getting on the internet. My...
    1. Change the administrator password for access to the web interface on your router.
    2. Change the default gateway (192.168....) to another one.
    3. Enforce security with a share key you give only to those you want to allow access (several protocols are available)
    4. Enforce MAC filtering: You clone (enter ) the MAC addresses of all the machines you want to allow access. Any machine the MAC address of which is not registered (cloned) on the router will not be allowed.
    5. Enforce safety measures: Keep the router out of reach of the persons you do not allow, because they can reset and sneak in, especially if they seem to be more computer-savvy than you. (No offense meant here).
    6. Periodically, check the log of the wireless access to identify the unauthorized machines that may be piggybacking your network.
    These are the basic steps: If you can secure the router with a password and enforce MAC filtering (Forbid all machines excpect those with a MAC address entered by you) you make things harder for this intruder.
    Hope it helps.
    You should specify the Model number of the router. It helps.
    Dec 10, 2009 | Belkin Computers & Internet
    I just installed my HP officejet J6400 on my wireless. Sometimes it allows my wireless connections to work with our laptops - sometimes not. Today, not. I just tried to uninstall some programs in an...
    try changing channel on router. had same problem, the school behind house had their network on channel 11. I changed to 6 (another std) and solved all problems.
    May 28, 2009 | Office Equipment & Supplies
    How to change the password?
    Hi there
    If you don't know the admin password then your pretty much stuffed unless you can get hold of a boot cd which will allow you to hack the password and change it so you gain access to the admin account. there is such software but its highly illegal
    Jan 08, 2009 | HP Compaq nx6110 PC Laptop
    Wireless
    Well once it is reset, in the configuration section of the router, for setting standard passwords, you can change the password, which is advisable.
    Next, for setting up a private wire/wireless network, My way of doing it is by setting the system up to Only allow Certain Mac Address's from the computers that are allowed to access to the internet through yours
    To get the MAC Address, Hit Start, Run Program, Command Prompt. Then in Command Prompt, enter this string line: ipconfig /all
    From there, it will give you the MAC Address for that computer. It should be a total of 12 Alpha Numeric Digits, Spaced with dashes between every 2. With that, you go into the router and in the Mac Address section for computers allowed to connect to your network, you enter in all the MAC Addresses that are allowed to use your network. Save, then it should refresh the page once that is done. With that, it makes a very hard to break Network that actually doesnt take much time. I was quite surprised 4 years ago to find that this was the easiest way to really set up a near perfect network with no issues
    Oct 29, 2008 | Linksys Wireless-G WRT54GS Router...
    I can't add a laptop computer to my network
    what o/s if vista need to put in password to vista and setup network making sure network named the same then r/click drive c: or d; which you want accessible and allow access. reboot try connection
    Jul 10, 2008 | Belkin Computers & Internet
    Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
    79 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
