Question about Sony KDF-E55A20 55 in. LCD Television
Television problem after a few minutes of turning the t.v. on, the audio and video goes out for approximately 30 seconds and then comes back on playing for several minutes and then goes out again.
  • 666irish Oct 13, 2008
    My problem is similar but the screen got off but I can still hear the actors in the background. Two nights ago it started to fail (screen go black) every 30 minutes for a 30 second duration, thenthe screen wuld be restored. No it happens every 2 minutes as if the 3 LCD's were failing. I've called for service as I'm under a warranty and will determine the cause.
  • psolleder Oct 24, 2008
    When I turn on the TV, both audio and video work for about 3 to 5 seconds. Then the TV, both audio and video go blank, after another 3 to 5 secons both audio and video come back on. This cycle continues to occur while the TV is on. Is there something I can do to fix this problem.
  • 320 Answers
Try changing the lamp, as sometimes an old or weak lamp will cause this symptom. USE AN ORIGINAL SONY LAMP as the replacements are unreliable
Posted on Oct 18, 2008
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Sony KDF-60XS 955 Video & audio goes out, comes back on
If the lamp fails to fire yes you will loose audio as well.
Aug 31, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv Audio & Video go off and by using remote channels or sound etc...back on
sounds like a solder problem where the tuner attaches to the chassis. Or possibly a weak capacitor in the video circuit. If youd like a service manual for the set let me know . I know where to send you to get it for 10.99. Hope this helps
Dec 22, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Sony KDF-E55A20 55 in. LCD Television Logo
145 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
