Question about HTC Touch Diamond Smartphone
Htc touch vibration and freeze problems
If my htc touch is powered off for a while, when I try to power on, it asks for pin but then, it only vibrates and the touch screen freezes. I try to restart it, take out the battery, everything I remember, and nothing, the vibration goes on.
The only way I can manage to make my htc working again is connecting it to the power supply.Once connected, the vibration stops and the screen works again.
I just bought it and I'm very disappointed with this. What can I do to solve the problem?
SOURCE: touch screen not working
the only solution i have found...replace the phone
Posted on May 19, 2008
  • 6 Answers
I have the same problem with my HTC touch everytime my phone loses service for a few hours the touch screen no longer works but they keep telling me that I have water damage so just because the indicator is pink (its in a stupid place anyways) I have had to pay for three phones and I got one free
Posted on Jul 15, 2008
SOURCE: HTC Audio manager is not working. Giving error
Dear take a backup of your mobile memory data (memory card data backup is not required) and then go to Start>Settings>System (Tab)>Clear Storage, This will reset your mobile and that would all Audio Manager error.
Posted on Jan 08, 2009
SOURCE: htc touch diamond vibrate problems
The instruction given in the user's guide are WRONG, which infuriated me. To perform a hard reset, hold down the power button and turn the phone off. Then, while holding volume down and the center button, turn the phone back on. It will give you the hard reset prompt immediately. Follow the instructions. I hope I saved you the stress I went through.
Posted on Feb 05, 2009
SOURCE: HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Posted on Feb 10, 2009
Why my htc explorer wont stop vibrating and cant power on.
your phone have hardware problem so go to the service station to resolve
May 16, 2017 | HTC Explorer A310e Black Android 2.3...
Why my htc explorer wont stop vibrating and cant power on?
dude its a serious problem...let it checked by any harware expert..we can only solve your s/w related problem not h/w...So go to a reparing shop.
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
My htc hd7 does not stop vibrating
its a software problem Hard resetting the device will solve the problem.
Apr 19, 2013 | HTC Touch HD Smartphone
Vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
Sep 06, 2009 | HTC Touch HD Smartphone
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
HTC diamond no longer Vibrates
The vibrate function of a phone is just a simple motor that pulses back and forth, creating a vibration. Just like any other motor, these can burn out. If the phone is still under warranty, you should be able to get it replaced. If not, an electronics repair shop may be able to fix it, but depending on parts and labor, you may be better off buying a new phone.
Mar 25, 2009 | HTC Touch Diamond Smartphone
Feb 10, 2009 | HTC Touch Diamond Smartphone
Htc touch diamond vibrate problems
Dec 28, 2008 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
169 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
