Question about Car Audio & Video
Kicker ZX300.1 shuts off after long play at high volume
I can't figure out why the amp shuts off after long play music at a high volume and when i turn the stereo off for about 5 minutes then turn it back on the amp works again.I'm not sure if it's a bad ground or what it could be it's in my trunk of my car so i think it would have enough ventaltion of air to keep it from overheating.Any advice would help please.
  • b4imbroke Mar 19, 2009
    I got the same problem with my Kicker Kx550.3. I'm running 4 gauge for the ground (which ran to the frame) and positive (which ran straight to the battery). I'm running 2 kicker 10inchs (4olm) speakers in series off the sub channel. I have a stock head unit and just recently purchased a Phoenix Gold line driver to make sure my amp is getting enough volts. The fan is working properly and the gain and bass boost is all the way down. As soon as turn up the gain the amp goes into this protective mode. The same goes for the bass boost. What am I doing wrong or whats up with these kicker amps?
  • 631 Answers
It's probably overheating and the thermal protection circuit is shutting the amp down.
If it has a fan, the fan may be defective. If I'm not mistaken, the fan only runs at high temperatures so if you check it, you need to do so when the bottom of the amp is almost too hot to touch.
If the fan is working properly, you may be driving too low of an ohm load.
If it's neither of those, get the amp up off of the mounting surface and use an external fan to move air across the bottom surface of the amp.
Posted on Oct 11, 2008
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
How do I tune my KICKER 08ZX1000? I have the amp running to alpine type r 12 inchs at 2 ohms but I don't know where the bass boost , gain, and crossover knobs should be pointing or what one to turn up...
To start, turn the gains on your amp all the way down. Bass boost should be off (this us used if you listen to your subs at low volume, the boost will heat your amp up quick if you use at high volume). Then turn the volume on your headunit up to 3/4 full. Make sure the filter on your amp is on low pass. The crossover point should be at it's lowest too. With all these in place, you can begin turning up the gain. You will have to decide at what point to move the crossover point. Since there are different styles of music, you will have to listen to where you feel notes are "dropping off" from the music. Adjust the crossover point to your liking, but remember that subs were made to reproduce low frequencies. Hope this helps
Aug 20, 2011 | Kicker Car Audio & Video
Amp shuts off when higher volume
might not have enough voltage going to the amp. depends on the size of the power wire too. had the same problem with mine, had to upgrade my wires, i couldnt turn it up past 14 with out it shutting off and then back on.....
May 12, 2010 | Kicker KX600.1 Car Audio Amplifier
Kicker CVR 10" "stuck"
sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
My amp goes into protection mode at high volume
need more info, make and model of amp and subs please
Feb 18, 2008 | Kicker DX350 Car Audio Amplifier
Car Audio & Video Logo
319 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
