Question about ViewSonic N3251w 32 in. LCD HDTV
I am trying to hang me tv.
On the back I have 10 screw holes and 6 of them have screws in them. My bracket only reaches to the screw holes that have screws in them. Can I remove the screws and put the bracket on?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Yes do that to save your time .the left over holes were definitely for some other kind of stands & hanger
Posted on Oct 11, 2008
I am trying to hang my tv, I have the appropriate mouting bracket for it but when I try to screw in the bolts on the back side of the tv (the 4 plated screw holes) the bolt will only screw in not even a...
Sounds like you are attempting to screw in the wrong length of bolt. Tv's generally use a shorter bolt and you should NOT attempt to screw it in any more than it will physically go - remember, there is sensitive electronics behind those holes that may break when you screw something in too far.
Just screw them in as far as they will go and leave it at that. Alternatively, go down to your local hardware store and find a bolt of the same size but shorter.
May 04, 2011 | Toshiba REGZA 52RV530U LCD TV
Took 6 screws out of back of stand on my Olevia TV, but still can't remove stand so I can hang TV on wall
I just wrestled with this problem. The screws were backed all the way out but I could not remove the stand. I had to remove the screws completely from the holes, then the stand can be pulled down then off.
Oct 19, 2010 | Olevia LT32HVM 32 in. LCD Television
Mounting it to a tv stand
Use the upper holes. Should be either a 100 x 100 mm (4" x 4") or 200 x 200 mm (8" x 8") or 100 x 200 (4" x 8") on this size television. Most mounts show the mm spacing, so purchase a mount that works with your spacing.
Jun 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a 32'' Technika tv and have recently bought a tilting wall bracket do u have to put screws in the back of the tv????
There should be screw holes in the back of your TV.You might want to make sure your bracket screw holes line up with them.
Feb 27, 2010 | Televison & Video
How do you remove the stand of a grundig gu22wdvd3 so we can put it on a wall bracket ; it has the holes for a bracket to fix into.
First remove the two screws from the underside of the base, pull the oval base clear from the stem. This will reveal two screws within the stem, remove these and the four on the back of the stem. Job done, hang enjoy.
Nov 15, 2009 | Grundig GU22DVDPX 22 in. LCD TV
How do i mount it on a wall bracket ... like what screws do i take out the back of the tv to attach it to the bracket
first buy the right bracket for weight of tv there is 4 big black screws near center of tv ( IF FITTED )take them out place bracket over 4 screw holes then use the 4 screws you took out make sure they are tight ( DONT FORGET TO TAKE STAND OFF )
Oct 12, 2009 | LG 37LG30 37 in. LCD HDTV
Bike basket brackets broke. the black brackets that screw on the handlebars broken away from the screws.
Without more info I will recommend using flat washers over the holes wher the screws broke away. The holes in the flat washers must match the diameter of the screws but the flat washers must be big enough to cover the holes in the brackets. If the brackets themselves are broken you might try getting some pipe hanging material from the hardware. It comes in strip form usually copper with holes prepunched in the strips. You will also probably need bigger bolts and nuts so the heads don't pull through the holes. Please let me know if this helps.
Apr 25, 2009 | Cycling
What screw holes are used for wall mounting a Sylvania 37 in LCD
the tv only weighs 55 lbs yes those are the holes 4 of them your bracket may have other screws if the bracket is thick
Mar 15, 2009 | Sylvania LD370SS8 37 in. LCD Television
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
ViewSonic N3251w 32 in. LCD HDTV Logo
157 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
