Question about Krups 848-70 \ 848-42 Aqua Control Cordless Electric Kettle
Krups kettle explosion???
My krups elec kettle just blew up. What the H--l is all that white powdery stuff that went everywhere????? There was still a teeny bit of water in it when it occurred.
  • Anonymous Mar 31, 2009
    Same thing....kettle blew up and the same white powder was everywhere. Anyone know what is going on?
  • Anonymous Apr 07, 2009
    same thing here.. black coagulating smoke flew into the air, condenced and fell as black rain
    Champion:
  • 279 Answers
Go to krupsusa.com customer service
Posted on Sep 18, 2009
Krups kettle does not boil water
Sounds like a faulty internal thermostat or it needs to be adjusted.
Dec 06, 2013 | Krups Kitchen Appliances - Others
My pot has a slow leak. I have tightened all the screws and bolts on the bottom and it still leaks or seeps.
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is the highest. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You will have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealant that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
Feb 12, 2011 | Cuisinart CJK-17BC Cordless Electric...
Water is leaking from the bottom
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You mayl have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
Meir Elazar
Feb 11, 2011 | Braun Kitchen Appliances - Others
I misplaced my manual for my sunbeam model 1128 warm mist humidifier and would like to know how to clean it....there is a white powdery stuff coming out of the base, how do i get rid of this....or could a...
the white powdery stuff is minerals, use a vinegar solution to warm water 1 part vinegar to 4 parts warm water. let it soak in the humidifier overnite or during the day and rinse with warm water. You could also use clr using bottle directions.
Dec 03, 2010 | Vacuums
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
Nov 14, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle keeps shutting off prematurely, from day one.... I lost my receipt
Buy a new one. Take the defective one, repack it in the old box and return it with the new receipt. Av a cup o tea.
Nov 11, 2010 | Krups FLF2 Cordless Electric Kettle
Krups Tea Kettle isn't working. I believe the problem is in the handle. It doesn't heat the water.
hello,
the handle has noting to do with the heater what you need to check on is the connection from the power supply if the connection is alright then you will have consider the element it is the heat provider connected to the wire it means that it is weak it need to be replace with a better one the element is in silver colour you can get it in any technical store/shop around you.
thank you
Jun 10, 2010 | Krups Stainless Steel Electric Kettle...
Krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups 848-70 \ 848-42 Aqua Control Cordless Electric Kettle Logo
332 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
