Question about Canon PIXMA MP470 All-in-One Printer
How to print entire UserGuide at one go, please
The on-screen manual only prints what is showing on the screen, at a time. Takes a  long time to print all the screens for even one subject; also very  wasteful of paper.
  • 1 more comment
  • no sunshine Oct 11, 2008
    It didn't work, sorry. I have an Apple Mac/
    I have the on-screen manual for Canon PIXMA MP470 printer on my desktop, downloaded from the installation CD. When I select "Print All"(which is the usual setting) it only prints the Userguide text actually visible on the screen.. there is nothing wrong with the printer, it normally always prints all. the problem is peculiar to this particular PIXMA MP470 User guide. Sorry Wix, neither of you solutions have worked.
  • no sunshine Oct 16, 2008
    The result I found today is brilliant! [Retrevo.com manuals].
    The delay is because it wasn't notified by email.
    Thank you very much somebody.
    Best regards,from 'nosunshine'. The sun is shining here now, with this answer. 16 Oct 08
    Sergeant:
  • 264 Answers
You should make a right click on the manual and give the print command from there (Do not open the manual).
Also manuals usually has some blank pages in between, so the wastage of paper will be there for sure if you print the entire manual at one go.
Posted on Oct 11, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, Is the manual single PDF file ?
If so, while printing, select Paper Range as "all".
If you have multiple files, you may have to combine them into a single pdf file before printing.
If I didnt get your question, please update on the situation so I do not make any assumptions.
thanks, :)
    Sergeant:
  • 352 Answers
I just tried this link and downloaded the manuals for your unit successfully.
http://www.retrevo.com/support/Canon-MP470-Multifunction-Printers-manual/id/3124ci176/t/2/
anaanymous
  • Canon Master
  • 6,487 Answers
Try to save first a copy of the userguide to your computer then try to print it now , that should do the work for you, because sometimes when you try to print a userguid direct from the internet its a problem with the internet browser that you're using....
Hope that helps...........
    Genius:
  • 1,913 Answers
Press control + p then select your printer then slect page range all.select this option buton.also u can set print setup. manually.
other if u have long doc then press crtrol A to select manual then paste in notepad then control +
p then u can get print in costing of paaper.
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
I have a Sakar speakerphone HT555ID, but I lost the userguide when the process of moving. Could I be sent a Userguide or manual. your response is awaited. Thank you. johnnyjones36@live.com
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 14, 2011 | Sakar Talking Caller-ID Speaker Phone
How do i use the prt scr button
Whatever happened to the Print Screen key??
If you did computers back in the 80's (DOS days) you probably remember using the Print Screen key on your keyboard to print a copy of whatever was on the monitor screen at that time to your printer. It wasn't used that much because back in those days it took forever for a dot matrix printer to print out the entire monitor screen. However, it came in handy once and awhile.
Microsoft has turned the key into into a "Snapshot key" which, as that term implies, takes a snapshot of the monitor screen.
After taking the snapshot, in XP simply click on Start, All Programs, Accessories and Paint. Then click on Edit followed by Paste and Voila! There's your screen snapshot in living color staring you in the face!
Now you can use "Save As" and save it with a .jpg/tif extension (etc.) and/or send it to your printer using File, Print.
If your keyboard Print Screen key performs more than one function you will have to experiment a little to get it the key to perform the Print Screen Function. Try holding down the ALT, SHIFT, or CTRL key (or any "special" keys unique to your keyboard) when you hit the Print Screen key in order to get the key to perform its Print Screen function.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 23, 2011 | Compaq 135227-001 Keyboard
I have a HP laptop I like to printscrren couple of page How can I do it please !
On a laptop, the print screen button is designated by "prt sc" or "prt scn" -- look for a button in the upper right portion of your keyboard. You will need to press and hold the the Function (usually "fn") key then tap (press and release) the button with the designation for print screen on it. This takes a "snapshot" of whatever is on your entire screen and temporarily saves it to the clipboard (like a "copy" does when you copy and paste something). If you wish to just capture the active window, hold the Function key, hold the alt key, then tap the print screen key. This only works on some laptops, not all. The easiest way to get to the picture you just created is to open the program Paint. Once open, press and hold ctrl (control) and tap "v" - this will paste the snapshot of the screen or window. You can crop, circle things, etc in Paint, then save the file or print it.
Jan 30, 2010 | HP P2360AA Keyboard/Mouse
What does the key with the letters PrtSc SysRq on an acer aspire do (whats its function)
if you hit just the prtsc sysrq button and open up a blank paint document, you can paste an entire screenshot into a picture document. if you hit control alt prtsc (It's short for print screen) you can take a screenshot of just the current window.
Please give me 4 thumbs if this helped!
Dec 06, 2009 | Acer NSK8458AN Keyboard
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
Adds on screen not printing whats on the screen
Call Canon at 800-828-4040. Select technical support. You actually get a live person.
They can e-mail you the manual in PDF format. It takes about 5 minutes.
Jan 10, 2009 | Canon P1-DHV Calculator
Canon i865 printer
Hi! I've got same problem. Canon userguide says that 5 flashes means the print head is not installed/not properly installed, or it is defective.Not yet sorted problem out - new print-heads are expensive!
Feb 12, 2008 | Canon i860 InkJet Photo Printer
Printing takes a very long time
In this case you can bypass the spooler by the following steps:
1. Right click the printer icon & left click the printer properties
2. Click the Advenced tab in the printer properties.
3. Select the option PRINT DIRECTLY TO THE PRINTER & UNCHECK THE OPTION SPOOL THE DOCUMENT.
4. Click apply and ok.
5. Try printing.
Feb 08, 2008 | Office Equipment & Supplies
Canon PIXMA MP470 All-in-One Printer Logo
66 people viewed this question
old marine
old marine
