Question about Sony Cyber-shot DSC-W50 Digital Camera
E:91:01 sony cybershot flash not working, error code E:91:01 flashing on it, any help grateful. #
  • kait_lin_6 Oct 12, 2008
    camera flash does not work and it is flashing error code E:91:01
  • BoBBK Oct 16, 2008
    I have the same problem and have not received and answer from other usuers
  • 74 Answers
Hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Posted on Oct 17, 2008
Sony Cybershot DSC-W55 flash not working Code
GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT INITIALIZE CLICK OK.
Aug 10, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Camera is flashing "E:91:01" ON THE SCREEN. WHY?
The flash fuse on the main board or flash board is bad. Contact your local Sony service center for repair as this is possibly a short circuit problem but first try this......
I found a forum that talks about your error. Here is a quote from the forum:
TO SOLVE FLASH ERROR sony cybershot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL.
please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
E:91:01 in DSC-W80
I can't recall all the Sony error codes off the top of my head, but I believe E:91 is that your flash is not working.
Can you take pictures at all or do you get just the error code? If you can take a picture with the flash off then your flash needs to be replaced.
If you can't use the camera you need to first press the reset button, then reset all camera settings to default.
1-3. PROCESS AFTER FIXING FLASH ERROR
When "FLASH error" (Self-diagnosis Code E : 91 : 01) occurs, to prevent any abnormal situation caused by high voltage, setting of the flash is changed automatically to disabling charge and flash setting. After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the HOME screen.
Method for Initializing the Flash Error Code
Initialize
Initializes the setting to the default setting. Even if you execute this function, the images stored in the internal memory are retained.
1 Select [Initialize] with v/V/b/B, then press z. The message "Initialize all settings" appears. 2 Select [OK] with v, then press z. The settings are reset to the default setting.
To cancel the resetting
Select [Cancel] in step 2, then press z.
· Make sure that the power is not disconnected during resetting.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Affordable Digital Camera Repair
Sep 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flash is not coming and error code is E:91:01
Hi!
E:91 is flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center or if they ask too much, feel free to contact me at toms.safranovs@gmail.com
I work in Sony service center.
Tom
Jul 17, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I use w210 Sony Cybershot! Error E:91:01.
I use w210 Sony Cybershot! I was taking pictures out in the sun, when I saw smoke coming out the camera and the camera become very hot. I also saw that I was using the camera bymistakely in the twilight mode out in the sun. And since then I tried intitializing it but the Error E:91:01 and flash symbol wont stop blinking. And flash Seems to have stopped working. Please help me to solve this problem
Jul 14, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Flash of sony cybershot dsc-w200 is not working
i think i had the same problem, if u press the home button and then press shooting then hit the flash button on the right hand side it should change the mode.
Jun 22, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
E91:01 error code W80
I will forward a link to a page where you can get the information regarding this error message.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002686
Jun 16, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
E:91:01 Error
E:91:01 is error code related to Flash Circuit abnormality. It requires qaulified technician to fix and such person would be available at nearest Sony repair shop.
Jun 03, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cybershot
according to the manual and E:91 code means "a camera malfunction that you cannot reverse has occurred" rhe corrective action states "Press the RESET button" Hope that works for you. I have a cybershot with a lens problem and Sony wants to charge me $190 to have it fixed
Aug 31, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
348 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
