Question about Kenmore 24032\24036 Top Load Washer
Changing a belt on a kenmore washing machine
I'm trying to replace a belt on my washing machine. we removed the backing
but cannot locate the belt were we where told it would be.
  • 2 more comments
  • kayla_vb Dec 02, 2008
    We have a 80 series kenmore washer, that won't spin anymore. I think it's the belt I have the washer tooken apart so I can check it out but I can't see any belt where would it be located at and is that even the problem?
    I cannot locate it either you'd figure it'd be in view.
  • Anonymous Dec 16, 2008
    how do I remove the back from my washer?
  • kelsirae Jan 05, 2009
    We just followed these extremely helpful directions...put it all back together... but now it is barely spinning. Did we do something wrong?
  • 550 Answers
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Posted on Oct 13, 2008
  • 2 more comments
  • AlmostBob
    AlmostBob Oct 13, 2008
    here is the details anyway
    usually it is a gearbox drive coupling, designed to break on exceptional loads
    whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
    dissassembly instructions vary slightly between models
    • remove trims from ends of control panel
    • remove scres under trims
    • raise control panel and flip it over backwards
      (note: do not dislodge air tube from level selector)
    • remove brass retainer clips
      (note: position for reinstall)
    • remove lid switch connector
    • remove lid and body
    the motor and gearbox are now exposed
    • undo bolt(s) holding spring clips to pump,
    • remove spring clips holding pump to motor(note position for reinstall)
    • unto bolt(s) holding spring clips to motor
    • remove spring clips holding motor to gearbox
    • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
    • remove the ring and spiders
    • take the ring and spiders to the local parts guy and get replacement,
      (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
    • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
      (note dont hit the legs they break.)
      (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
    • turn gearbox shaft 1 leg up 2 legs down
    • turn motor shaft 2 legs up 1 leg down
    • insert new rubber ring over gearbox spider
    • insert motor into rubber ring
    reinstall springclips
    pump
    pump springclips
    body
    control panel
    in reverse order to above
    gearbox coupling ~$17.00
    time ~25 minutes, but I do 3-4/month
  • AlmostBob
    endcap & Screw
  • C_moul Jun 29, 2011
    Can you take some pics showing how to do it step by step?
  • jcguggins
    jcguggins Feb 06, 2013
    where is the coupling located?
Can you take pictures on how to do it..
Posted on Jun 29, 2011
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
My washer is not thoroughly spin drying the clothes. I have to run it through 2 or 3 times on the spin cycle to get the clothes not to be dripping. It is 19 years old and just now started doing this.
it may be your agitator. 1
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Jan 31, 2011 | Kenmore Washing Machines
The belt on my Kenmore washer model no. 110.45091401 is shredded. How do I replace it?
REMOVE BACK PANEL ON FRONT LOAD WASHER PUT BELT ON LARGE PULLEY AND TAPE BELT TO LARGE PULLEY TAKE OTHER SIDE OF BELT AND STRETCH TO MOTOR PULLEY WHILE ROATING LARGE PULLEY WALKING BELT ONTO SMALL PULLEY OR LOSEN MOTOR BRACKET PAY ATTENTION TO LOCATION OF MOTOR BRACKET ALIGNMENT PUT BELT ON BOTH PULLEYS PUSH MOTOR TILL BELT IS TIGHT AND RETIGHTEN BELT
Jan 26, 2011 | Kenmore Washing Machines
Have located the worn out belt to the dryer..how to replace it? do you have too take the back off to replace the belt to the drum?
Please see the following illustrated description of how to replace the belt on most Kenmore Whirlpool belt drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144
Nov 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Need to replace belts
This model washer doesn't have any drive belts. It uses a motor coupling in place of a drive belt. If you need to replace the coupler, the following link explains how to do this:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
You have to remove the entire washing machine case to access the interior. The back does not come off. Its not as intimidating as it sounds, though. The part number is included in the link I provided and can be purchased at appliancepartspros.com for about $11. Just use the "Search By Part Number" feature. If you have any questions, please let me know. I hope this helps you.
May 08, 2009 | Kenmore 24032\24036 Top Load Washer
How do I replace the belt on this machine
take the back off and put the on the small pulley and pull the belt over the large pulley
Apr 20, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Older Style Top Loader Washing Machines
if the image on your posting is correct and model number 2 there is no belt washer is driven by coupler between motor and transmission it could be broke if washer drains but won't agitate or spin ..remove end caps on console by pulling up remove screws on each end of console lift console up and roll back remove clips on each corner and lift cabinet forward and off remove pump clips remove motor clips by removing screws first drop motor remove coupling and replace
Aug 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
9,145 people viewed this question
Sal De
fordexpert
Robert Rankin
