Question about Canon Office Equipment & Supplies
Canon copier IR2800 error code E 000999-384, any ideas please?
  • Malcky Oct 11, 2008
    Thanks for the quick response acdr, what does the code mean though?
    Genius:
  • 1,913 Answers
Uninstall printer driver and then software install again.
Posted on Oct 11, 2008
How do I clear error code E000003-0000
ppress additional functions, 2 and 8 then additional functions again
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON
I think, I dont have an ir2800 manual. This is an error in the fusing section, so it may come back and require some parts replaced.
Oct 21, 2011 | Office Equipment & Supplies
My Ir2800 canon photocopier is not functioning, if I switch the main power button on, I get an error message on the screen wit the code E000003-0000
these is temperature related error, fixing fault.
First you need to try cancel it, follow these steps:
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
If these doesnt helps change fixing film assy ( heater )
Hope that helps
Aug 16, 2010 | Canon Office Equipment & Supplies
Canon ir2800 is hanging after 2\3 copies what to do ?
How is it hanging.... What is wrong with it? Is it jamming or coding out? If it jams make sure the paper tray's are set to the same direction and size of paper in the paper tray. The knob for paper size input get's moved by the "Knob Mover".... Good Luck
Feb 28, 2010 | Office Equipment & Supplies
Canon IR2800 error 000051-0000
The code referrers to M3 not turning "ON". Make sure the connector ( J3040-2 ) is connected all the way in.... Cheak all of the connections on all the pcb.. Good Luck
May 13, 2009 | Canon Office Equipment & Supplies
Error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Apr 29, 2009 | Office Equipment & Supplies
E000003-0000
Hello 1999.We can reset the code together. And for many errors the copier can be reset,and then recover, then move on like normal. However the code you have (E000003-0000) means that an extremely temperature sensitive area of the machine misbehaved.And the copier gets really anal about monitoring this temp so the code may return as soon as the copier runs a diagnostic, but I can assure you we can reset the code so lets give a whirl and hope for the best.Ok, on your operator control panel, next to the nine key pad,is a button that says "additional functions".Locate it and we will perform a 3 step function that will allow you to enter "service mode" which will let you clear the code. Press "additional function", release it and then immediately press the 2 and 8 buttons simultaneously, release them and then press additional functions again. As I said this is a 3 step process that should be done in a smooth but timely fashion. If done properly this will summon a new screen that will show you a few "blocks" and the top block will say COPIER. Press it and a new screen will appearwhich will have several blocks across the top of the screen. One will say FUNCTION and you need to press it. Again a new screen. Look at the menu in the body of the screen and you will see CLEAR. Press clear. New screen again and look for ERR. Press ERR. After you have touched ERR notice the "OK" button in the lower right corner of the screen. Touch "ok". Now unplug the copier and wait a few seconds.Now plug that baby back in. The copier will attempt to return to a ready condition by "warming up". This is where the copier may notice a problem with the temp. Then make a copy. This will force the copier to run a brief diagnostic(which you wont see). If the copy successfully exits the copier then you should be ok. But the fact that the code occurred at all Means that at a minimum the copier had previously seen a problem and so the code may return. Hopefully, we just saved you the expense of a service call and all remains well. I hope I have helped you and I will keep my fingers crossed hoping it was merely a momentary problem. Good luck and take care. SPINAL
Jan 19, 2008 | Office Equipment & Supplies
Canon IR2800
e000007 is related to the fuser..you need to change the fixing film or clean the sensor
Sep 07, 2007 | Canon imageRUNNER 600 Printer
66 people viewed this question
old marine
old marine
