Question about Hitachi CP-S225 Multimedia Projector
No detecta entradas
Mi proyector hitachi cp-s225 no detecta entrada video ni rgb ni S video.Porfavor me gustaria que me ayudaran muchisimas grazias.Un saludo
  • rikburton Oct 14, 2008
    sigo con el problema necesito ayuda (gracias)
  • Anonymous Jan 22, 2009
    Tengo el mismo problema!
    uede alguien ayudarnos?
4 Suggested Answers
SOURCE: Vertical lines on my Hitachi CP-S225 projector
just changed bulbs on my projector a Hitachi cp-s225 wt and i still see a lot of blue and there are lines o green running down the left side
Posted on Feb 14, 2008
Marrie
  • 563 Answers
SOURCE: Hitachi CP-S225
Hi Ian
Your Projector is in need of a new Mainboard.
Must warn you that it could be a costly exercise
Posted on Mar 26, 2008
fathitkf
  • 1871 Answers
SOURCE: Fan running but the lamp is not on, I have
Hello :
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
heathgr
  • 442 Answers
SOURCE: Hi, our Hitachi CP-S225 will not work with our new
What did they say the driver was needed for. Aren't you just using the vga output of the PC to feed the video signal to the projector. No driver is needed for this
Posted on Mar 02, 2011
My citi ville download only 69%
There was possibly an error downloading. Try again
Feb 18, 2011 | Computers & Internet
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
El motor esta trabado
si se puede hacer pero de entrada es necesario desmontar el motor completo para desarmarlo xq no tiene espacio para hacwerlo montado y pues de cualquier modo podria salir algo caro y con algo de tiempo
Jul 18, 2009 | 2000 Lincoln LS
Fallo 1.- entrada baja en el circuito de temperatura del refrigerante del motor fallo2.- entrada alta en el circuito del sensor 2 de detonacion banco 2
tengo problema conla luz de chec, k es de un jaguar x tape ttambien sale la luz de cruise control not disponoble ..que puedo hacer?
Jun 27, 2009 | 2002 Jaguar X-Type
Falla en cobra 29 nh st
tienes un problema en el receptor verifica transistores de entrada del receptor lo que se llama en ingles front end ,osea mide todos los transistores de entrada posiblemente cojio una senal muy fuerte de entrada y estos se danaron
Apr 10, 2009 | Cobra 29 LTD CB Radio
Problema
hola tengo 1 ilo-32hd pero no me responde el control ni puedo cabiar de canal gracias
Oct 28, 2008 | iLO 3200 32 in. LCD Television
Scanner Mustek mod. 600 III EP -[ Plus
Hola Julian: Eso que comentas es el power de tu scanner, puede ser conectado a cualquier toma corriente de tu casa con el adaptador adecuado y no necesariamente a tu computadora.
Pasa que algunas computadoras como la tuya tiene entrada de power para conectar este tipo de devices para darle corriente a los scanner, parlantes o cualquier device externo que necesite power.
Ese cable lo conseguis en cualquier store de electronica, es un bridge. (un puente de corriente entre tu compu y el scanner)
Sino la otra alternativa es conseguir un power supply para tu scanner. Eso es todo.
Aca tenes el power supply:
http://cgi.ebay.com/15HB-power-supply-ADAPTER-15v-1A-HP-Mustek-UMAX-scanner_W0QQitemZ370092779651QQcmdZViewItem?hash=item370092779651&_trkparms=72%3A1156%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Oct 04, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Ayuda
Te recomendaria que utilizes un transformador variable para que puedas hacer mediciones del voltaje que alimenta la seccion horizontal. Me parece que la seccion horizontal esta recibiendo mucho voltaje y es cuando se activan los circuitos de proteccion.
Si usas el transformador variable empieza con 80VAC y mide la DC en tu TV, si en la entrada de el regulador de voltaje tienes mas o menos 130VDC a la salida tienes lo mismo, el TV te funcionara. Despues incrementa es voltaje a 100VAC y vuelve a hacer las mediciones.
Si despues de incrementar el AC a 110VAC el TV hace lo mismo, trata de medir la DC en la salida del regulador de voltaje. El voltaje aceptable seria de 130VDC a 135VDC.
Suerte.
Jan 16, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi CP-S225 Multimedia Projector Logo
46 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Electro Med Services...
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
