The car has a dipstick which has a spiral through most of its length. Cannot check oil. Familiar with proper use of dipstick. I think that the spiral is wiping oil from the inside of the dipstick tube and the oil is running down into the reading area when I pull the dipstick out. Repeated dipping doesn"t seem to help.
SOURCE: oil dip stick
Had the same problem last year - the plastic handle broke off and the
top of the remaining plastic was visible down the tube but was stuck
solid. Finally used an easy-out to get it out. Drilled a small hole
into the plastic and then threaded a thin easy-out bit into the hole
and it held enough for me to pull the dipstick out. Stupid design, a
plastic handle on a metal dipstick!
Here in Canada the Intrepid is badged as a Chrysler. Sounds a bit dodgey to me :-)
SOURCE: dip stick tubing
if the end that is on the bottom of the new tubing is smooth then the old one should twist out with a bit of force no particular direction to pull off though just twisting
SOURCE: 1992 cavalier trans dipstick tube
ther should be a brace welded to the tube it should bolt to the back of the engine, maybe the weld broke off the tube. if i can be of any further help just get back to me. please rate my fix as i strive for the best Thanks Ray
SOURCE: how to read oil dip stick
What engine is in your A4. Normaly if the oil is in between the hash marks on the dip stick thats good, If above or below hash marks this is bad. To properly check oil level start vehicle up let it run for 30 sec. Shut vehicle off and let it sit for aprrox 2min then check the level.
SOURCE: Oil Dipstick tube is broke, Where does it go?
http://carservicemanuals.blogspot.com/2008/06/download-dodge-ram-2005-service-manual.html
