Question about Kenmore Elite HE4 Electric Dryer
Broken Washing Machine
Washing machine won't agitate or spin. I have a Kenmore elite model number 26962505. How do I fix the problem?
  • 116 Answers
Frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Posted on Nov 30, 2008
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
Washing machine does not agitate or spin. Water
The motor couplings sound as if they have gone bad. They are between the motor and transmission. Set of couplings are less than 20.00 and cabinet has to come off machine to do this. If I knew model number I could tell you how to remove cabinet but without it there are several different ways. Do not take the back off tho no matter what you do. Less than 5 minutes and the body is off.
Feb 24, 2010 | Kenmore Washing Machines
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Jan 17, 2009 | Kenmore Elite HE4 Electric Dryer
Machine will not agitate
most likely it's either a broken belt, or the motor is going out. to check it you need to take the outside casing off, not sure exactly how to do that on that model. Anyway open it up, check under the drum for a belt, if the belt is in tact than it's the motor, in which case. Personally I wouldn't put in the effor to replace. as to where you can get a belt if it is broken, I don't know that either. Good Luck
Jun 20, 2007 | Kenmore 22422 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
