Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD640P - Fitting a new belt
I am trying to fix the belt back on to the motor and drum and cannot seem to get the belt on. There seems to be no slack in the belt. Can you provide some assistance ?
  • cdjemery Oct 11, 2008
    Have tried your suggestion and it will not go on - will not turn after a certain point
  • Anonymous Mar 17, 2009
    my belt has come off my hotpoint aquarius wf430 we have tried many ways to get it back on without success pleas help
  • 99 Answers
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Posted on Oct 11, 2008
I am trying to put a new drum belt on a hotpoint aquarius vtdoo reverse action
Posted on Dec 04, 2008
If its right belt its only way to do it.
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Yeah hello there , im trying fitt a belt two hotpoint washing machine wf100p , i havn't taken the back off putting the belt on the motor first the on two the drum wheel gradualy turning the wheel to put...
You are doing the right thing. Hook the belt onto the motor pulley, then onto the main pulley as far as it will go, use a few cable ties to hold it on the pulley and turn the drum anti clockwise, the cable ties will snap as the pulley turns. Hotpoint have made a tool for putting these belts on but you woudn't want to pay out just for one belt.Belt fitting Diagram link
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have replaced the belt on my Hotpoint tumble dryer but now my drum seems to have dropped and is catching on the motor. What have I done wrong ? and how can I fix this ? thanks.
Installing a new belt in a pain. there should be rollers that the drum sits on. take the drier apart, set the drum back on the rollers and place a shoe box under the drum to hold it up or have someone help you. Open the door and make sure the drum is lined up right when you are placing the cover back on. Good Luck.
Mar 14, 2010 | Dryers
I have replaced the belt on my Hotpoint vdt00 dryer but the belt seems to pull the drum on to the motor causing a scraping noise and its hard to turn around. their dosnt apear to be a bearing or anything...
look inside the drum is there three screws on the very back wall of drum,there is a bearing there,remove the belt,slide the drum forward and look at the back of the drum,there should be a shaft sticking out that slides into a slot that looks like a U in the back wall,that is the rear bearing that you get in a kit if you hear a loud squeaking sound that's the problem,if you sent the model number i could of told you the part number
Jan 31, 2010 | Hotpoint Dryers
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
Please rate my solution.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
Creda eco washing machine won't spin
It sounds like it needs new carbons fitting in the motor.
It is a fairly straightforward repair.
Remove the top cover, screws at rear, and slide top cover off towards the rear.
The motor is located at the top right right rear, you will see the drive belt.
Slacken the bolt that holds the motor, and push the motor down towards the top of the drum.
You will see the 2 brush holders, they will be either black or white, pull the wires off the holder terminals, and depress the plastic`lug that holds the brushes in place, slide the brushes out of the motor.
fit new genuine Hotpoint carbons, and follow instructions on packaging. Push the leads back on to the carbon terminals.
Tighten up motor, and make sure the belt is reasonably tight.
Job done.
Test on final spin before you refit top cover.
Plz rate my solution.
Thanks.
Dec 23, 2008 | Washing Machines
Changing belt
the belt seems to be too short, how can i get the belt on the motor and the pulley on the drum?
Mar 29, 2008 | Kenmore 44072 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
457 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
