Spin Issues HI, Just noticed that my alomst 6 months old washing machine has some problem spinning. every time the time goes to spinner mode ( clock time of 14 min)it resets to rinse mode with a clock time of 21min. & starts the rinse all over .. any ideas. what could be wrong??
  • autogizzmo Oct 12, 2008
    hi,
    well being the handy man around the house unscrewed the tub propelor.. & guess what i found,a Coin stuck in the out flow valve, now everything works fine.
    thanks anyway.
  • 99 Answers
Get manufaturer out under waranty,proberly moduale
Posted on Oct 11, 2008
DDT100A1WDB Washer/spinner...the spinner does not spin. I recently noticed it, after not using it for 7 months. How can I check underneath the spinner to see if a baby sock is stuck.
-It can wash but just not drain at all. That is what you asked. Right?
-Nothing will fall to under the tumble, may be to the drain filter, but not to under. This case most likely the computer is malfunction itself.
-How about try this:
-No clothes inside.
-Turn on power.
-Closed the door good like usual.
-Press cancel couple times.
-select to drain and rinse only then press start to see what it will do.
-Do not bother it. let it finished the cycle. After it done, open the door. If there is not water inside at all then you should be good back to washing business. all clothes will be happy.
Good luck
Mai
Jan 22, 2018 | Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Regards
Phillip
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Maytag centennial washer
Dogs inside of spinner are worn out. Take screw off top of spinner and you will see four dogs that are easy to change.
Sep 30, 2017 | Washing Machines
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
Maytag neptune MAH8700AWW washer will not complete the spin cycle. It spins both directions but never goes past 6 minutes on the display. Eventually you get the "DC" error. It does this with or without...
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(&^%
Sep 15, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Spinner will not spin
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
Spinner not spining on quick wash
THE cloths is not dryed anough till it spind lavamat w 80 washing machine
Oct 19, 2008 | Washing Machines
GW709 MACHINE SMART DRIVE LOAD 7.5
hi
if it washes ok but won,t spin it canbe pump if it has not pumped all the waterout or can be lid switch,but normally they won,t wash if the lid switch is funny so i would be checking the pump side of things
cheers grantsreps
Aug 30, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
