Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence changedcstk still seeing double
  • kyle5252 May 11, 2010
    where are the ohm resistors? if the ic is out how can I fix
    Problem Solver:
  • 22 Answers
Slinterious can you email me the schematics for this tv panasonic pt-53tw53
Posted on Feb 08, 2009
  • Panasonic Master
  • 8,617 Answers
Did you check the low ohm resistors? Its not uncommon for some of them to be opend when the ICs go out.
Posted on Oct 11, 2008
Blurry
Ur tv have a problems call convergence,it dead.The convergence board the 2 STK convergence ICS,and some or all it resistors are dead.All these parts are dead,must be change to solved the convergence problems.The shop will cost u $300-350 for the parts and labors.
May 21, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Seeing double
You need to replace the convergence board in your tv .
Also you have mentioned it is 5 years old so its time to replace it .
But it will not be cost effective one .
SAM ANDERSON
Sep 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Converge seeing double red and blue
That will be a convergence issue that needs to be repaired by a technician.
Jul 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Seeing double on my samsung rear pro
The convergence IC's are definitely bad. They are not a plug-in device, they solder in so this is a big job.
Mar 30, 2009 | Samsung PCN5425R 54" Rear Projection...
Seeing double
need to replace the convergence ICs and possibly the convergence resitors . You need STK392-110 ICs you can get the ICs and the convergence resiistor kit for your model at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jul 28, 2008 | JVC AV-48WP74 48" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Double lines
There is a manual convergence setting. Press Menu until you see the option of convergence. Save settings by pressing Power until you see Save Ok. You can exit the convergence screen by pressing the PIP button. 0 reloads the convergence. It will periodically go out of wack again.
Dec 22, 2006 | Apex Digital GB4308 43" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
