Hoover bearing number S99203 010BRS I Need A replacement
  • Cre2mboy Oct 13, 2008
    LOOKING FOR ONE OF THESE- hELP!
  • 99 Answers
Please give me model no. We can supply.
Posted on Oct 11, 2008
  • Reg Woolley
    Reg Woolley Oct 13, 2008
    Hi we can only source this with a model no.Most bearings come as a kit 2 bearings and water seal.If you can get back to me tonight might be able to advice price etc.
Hoover SpinScrub 50 wheels won't spin
The bearings in the turbine are prone to seizing because of moisture. Take it to your local vacuum repair shop and have them repair it. At my shop we re-grease the bearings and it's better than new. If there is too much damage the turbine will need to be replaced
Sep 07, 2017 | Hoover Vacuums
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
Kristie,
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Hoover Logic 1300 - which main bearing do I need?
comes in a called bearing kit ie 2 bearings and a bearing seal
Mar 01, 2015 | Hoover Washing Machines
Replace the bearings on hoover hwb240-80
its called a bearing kit the drum has to come out
Feb 19, 2015 | Hoover Washing Machines
I replaced the belt with part# 40201 on my Hoover model# U5473-900; to only have it break again in 5 seconds! Is there something missing that holds it on that little bar?
Greetings,
When a brand new belt breaks in 5 seconds, this can only mean 1 of 2 things.
1. The roller brush itself may be bad and need replacing. If the roller brush's bearings lock up, and the brush can no longer spin freely, this will cause the belt to burn up immediately after you turn the vacuum on. You may test your roller brush by taking it out of the vacuum, and hold it on the very ends of the brush with your fingertips. Make sure you are only holding the bearing caps and not the brush itself. While holding the two bearing caps with your pointer fingers, try to spin the brush with your thumbs. Does the brush spin freely? If no, then you'll need to buy a new roller bush for your vacuum, unfortunately the bearings are not sold separately on Hoover vacuums. If the brush did spin freely (you should get at least 7 rotations out of one spin) then see reason number 2 below.
Your model uses Hoover Agitator Brush Part 48414132.
2. The belt was installed incorrectly. When a belt breaks immediately like this it can also be a result of it not being installed properly. When installing the next belt, after you have put the roller brush back into place, pull forward on the belt to make sure that the brush spins when you're pulling forward. Sometimes I pinch the belt underneath of the brush roller, and it will not spin freely, and will burn immediately if the belt is pinched.
It really can only be one of these two problems. I hope that this repair solution was helpful to you. If you need me to clarify something, please just request clarification here. If it did help, please be sure to rate my repair Helpful. Thank you so much!
Chris J.
Mar 13, 2010 | Hoover Vacuums
Brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Apr 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
WHERE CAN i FIND A VEW BRUSH FOR MY HOOVER UPRIGHT SELF PROPELLED CLEANER PART NUMBER 48414004
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783436
Generic problem for all Vacuums
WHERE CAN I FIND A
Posted by NORMARL on Jul 14, 2008
WHERE CAN I FIND A VEW BRUSH FOR MY HOOVER UPRIGHT SELF PROPELLED CLEANER PART NUMBER #48414004
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Well, you can buy the brushroll in 2 different places, your local vacuum cleaner dealer in your area or you can call the Hoover factory cust serv and ask for the parts dept and they can ship you one. Or, you may have a metal brushroll with replaceable brush strips and they also can rebuild the bearings on either end, it might be cheaper but you need to weigh the cost between the rebuild and the new one. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
I have a Hoover 5030d & its making a noise as the barrell turns. If spun manually it sounds a bit like a bearing. Is it easy to change a bearing on a Hoover 5030d?
It sounds like the engine shaft bearing. Fairly simple to fix or replace with the correct tools and know how.
Be sure to take photo's of the motor, tension arm, and any wiring.
You'll need pliers to remove the clamp from the fan, then remove the belt from the motor and make sure that's were the problem is before going any further.
Jul 06, 2008 | Hoover Dryers
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
