Question about Maytag 7.0 Cu. Ft. Electric Dryer
Dryer not heating enough
Model #ede8406ace was given to me after being in good working order. It was hard wired prior and now I added a three prong plug. There is three poles in the back of the dryer and there is a light blue wire that Looks to be a ground? I connected all wires unsure if they are correct since I did not take them apart and I attached the blue one to the frame. All works, however the dryer gets only warm not hot. Vents are clean. I believe it is a wiring problem and I do not have a schematic.
  • michaelwelle Oct 13, 2008
    there are three wires loose inside the body of the dryer. Two are white one is the ground. I believe I connected them backward at first and may have blown a thermo. fuse. Thus it is very possible I am wired correctly now yet the the low heat exists due to the initial incorrect wiring?
    Genius:
  • 1,122 Answers
If you have a three wire cord the middle wire on the cord always goes to the middle nut on the terminal block,the other two wires it does'nt matter you just out one on each side of the terminal block,you should have a green ground wire mounted to the case,this is how you install a three wire cord,if four wire it's the same but you have an extra green ground wire that also goes to thre case,let me know more-mike
Posted on Oct 11, 2008
  • MIKE major Oct 13, 2008
    if you blow the thermo fuse on the heater box you will get no heat at all,if you blow the main fuse nothing will work,do you have any wires going into the terminal block?the green wire is the ground,most all dryers have a black wire,white wire red wire on the block in that order,white is always in the middle,let me know how you do- mike
    why did'nt you get back to me before rating me?mike
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Kenmore Washer/Dryer Combo Unit Cord Issue
the extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
Sep 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
What do i do with the ground wire on the dryer. i changed from a four prong dryer cord to a three wire prong
Good day,
Actually nothing. The center wire in the three prong setup works as both the ground and neutral.
Look here.
Old 4 wire.
New 3 wire.
Make sure the grounding strap is in place.
Jul 15, 2010 | Dryers
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 | Dryers
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
My 220 plug is a three prong and the used dryer I bought has four prongs. Is there some type of adaptor I can buy to connect the two plugs such as what used for adapting a 110 line that has two different...
Hello Doris, You really don't want to get an adpater for this, (even if you could find one - they're not at all common) since the thickness of adding in an adapter would make the dryer stick out further from the wall, etc.
What you need to do is to get a new "pigtail" for the dryer that has the three (3) prong plug that matches your 220 Volt-AC wall outlet. These are available at most Home Depot, Lowes, Sears, or at any appliance or Hardware store. They don't cost all that much and will provide you with the correct plug and cord set for your house's electric dryer outlet.
The four (4) prong cord & plug has a separate ground wire in them, while the standard thre (3) prong plug uses the netural as the ground, or has a separate green wire running from the dryer cabinet to either a grounding screw on the wal plate, or to a ground ******** a water pipe (typically found in older homes)
Just be sure to unplug the dryer before changing the cordset out for the 3 prong one. Make sure the power is also off at the breaker panel too. Now at the rear of the dryer there is a small access panel where the cordset goes into the dryer. Remove that panle and you'll see three (3) connections on the panel along with a Green Grounding connection.
The connectors that get the power are the outside connectors, these are "HOT" and get 120 V-AC each (120 x 2 = 240 Volts AC) while the connector in the middle is the NEUTRAL connection point.
The wiring is straightforward and there should be a simple wiring diagram either on the access panel or the connection points should be labeled for each of the wiring fasteners (screws or nuts)
Just be sure to get the fasteners tight, and the new 3 prong cordset you buy should be long enough to reach from the dryer (when it's pulled away from the wall) to the house outlet. Typically they come in either a 3-4 foot length or the longer ones are 5-6 feet long. If in doubt, get the longer cordset. You can also check the wrapper of the new cordset, as they provide a simple wiring diagram also, to help you install it correctly.
http://z.about.com/d/electrical/1/0/r/0/-/-/DryerElectricalConnection.jpg
Just be sure to add the included strain relief, as instructed, onto the cordset and put the access panel back on when you're done and you'll be all set to use that "new" used dryer!
I hope you find this Very Helpful and best regards!
Nov 16, 2009 | Maytag PYE2300AY Electric Dryer
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
Four prong plug to three prong plug
Is the receptacle in the wall a four prong or three prong. You will have to match the cord on the dryer to the wall recepticle. If the wall is four prong the dryer cord has to be a four prong. The green wire with the yellow line, that is on the end of the dryer cord, is a cabinet ground and should be attached to the cabinet of the dryer and making good contact. The other three wires on the end of the dyrer cord attach to the terminal block.
Jul 08, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag 7.0 Cu. Ft. Electric Dryer Logo
64 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
