Question about Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone
2000 road king
Just purchased, has 22000 miles, looks & runs good,doesn't seem to have any issues. i would like to change all fluids,brakes pads,etc. to start fresh.
does any one have any advice on what oils,(motor,tranny, fork, etc.) i should use? thanks to all.
tommy
  • 91 Answers
Use a good brand of synthetic 20-50 in everything the primary fluid will last around 10,000mi the tranny fluid the same and the engine around 6000mi the tranny takes 3/4qt the pri takes 7/8qt and the engine gets 2 3/4qt check the levels with bike upright check engine oil level after warm up top off as needed
Posted on Jan 08, 2009
2002grand Cherokee hard brake pedal ineffective brakes
there are three reasons for hardening brake pedal:
1 . thebrake boosteris lack of pressure, need to change a new one.
2. the brake pad wearing too much , need to change a new ones.
3. the brake fluid can't flow into the brake disc side, have to check the brake hose and master cylinder tank.
welcome to ask more questions or visit us:
www.fiverhope.com
Oct 03, 2013 | Lands Phones
What would cause my pathfinder to **** in the stiring wheel? We have changed the tires, and the tie rod ends. It jerks so hard it pulls you off the road.
It seems like there may be a broken brake caliper which could cause the brake on one side to not release properly if at all. Also check for a low tire or poor alignment. tires lose about 1/2 to 1 lb of pressure per month and the alignment goes from normal wear and tear. It's probably most likely in the brakes. have them looked at as most places do it for free or for very little.
Dec 19, 2009 | Lands Phones
Which would you recomend better. a 2004 harley fatboy
not alot of difference fatboy is lower and for that reason i feel it handles a little better but if your heart is set on a bagger look for a road king ride all three and i think youll agree
Oct 12, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Issue with Harley regarding cam bearing - 2000 Road King Classic
our bike is out of warranty by 8 years.....should i ask for warranty on my 1987 FXR? or should i just man up!
Sep 29, 2009 | Harley Davidson KNG America 026711...
95 road king brake light does not work taillight works changed
I take it it does not work foot or hand control. look for your brake light switch right side of frame rail usually a goldish color or silver color. it has two plug in connectors. Unplug and put a test light to them. apply either brake. If the light comes on then you have a bad brake switch. replace it. if you have foot brake and no hand brake light then it would most likely be the brake nipple in the hand switch. but you did not say so I assume no brakes foot or hand.
Jun 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Front brakes failed
Is this using stock brake lines?  You could have kinked the metal tubing and possibly broke it when you straigthened it out.  I would suggest getting someone to help who knows what they're doing on brakes... pretty dangerous if you make a mistake.  With that said, the system *is* pretty darn simple.  The master cylinder is a pump and the caliper is the actuator.  If you have the reservoir filled with the correct fluid and the system has been bled properly, meaning no air in the lines, then unless it is leaking there is no reason you won't have brakes, unless the seals in the master are blown out.
If you need to start over... get a master cylinder seal kit, a caliper seal kit, and a bottle of the correct fluid from the dealer.  Both kits are around $20 and since your bike is 10 years old it wouldnt hurt to replace the seals.  Rebuild the master and the caliper according to the service manual instructions.  Also make sure you fully inspect the brake line to make sure you didnt kink it.
May 22, 2009 | Harley Davidson Harley-Davidson Motorcycle...
LOSS OF REAR BRAKES
Take the master cylinder off the bike and try to "bench bleed" it in a vise.Fill with fluid and put you finger over the outlet,push plger in with a screw driver.If no or very little pressure replace the master cylinder.
If it does pressure up install and bleed system one section at a time.When bleeding a dry system DO NOT LET THE RESERVOIR RUN LOW or you will get air in and be there forevere bleeding.
Jan 17, 2009 | Harley Davidson Harley-Davidson Motorcycle...
200 Harley 1200 Sportster, Shuts off when at idle at stoplight / stopsign, etc.
Offhand and initially, pls start by referencing the steps as outlined here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Electrical Problem 2002 Harley Davidson Roadking police mdl
Your gonna need a voltmeter and a multimeter to trouble shoot this. Invest in a service manual. They have extensive troubleshooting guide
Jul 17, 2008 | Harley Davidson Harley-Davidson Motorcycle...
FRONT BRAKES
very simple system my man. the brake handle connected to the master cylinder connected to the brake line connected to the calipers via the plumbing in between. so check your fluid level first if its low then top off and bleed those babies. also check the pads because as the pads wear the piston in the caliper moves further out so more room in the system so lower fluid level or you got a leak. or the master cylinder is bad. start with the obvious and dig deeper good luck and let me know tell me more about the malfunction too
Mar 30, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Harley Davidson KNG America 026711 Harley-Davidson Fat Boy Replica Phone Logo
219 people viewed this question
Top Harley Davidson Lands Phones Experts
Brian Mathews
Level 1 Expert
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
