Question about GE WBSE2090A Top Load Washer
COLD WATER WASH
MY HOTPOINT TOP LOAD WASHER TAKES AN EXTREMELY LONG TIME TO FILL WITH COLD WATER. THE HOT WATER DOES NOT HAVE THIS PROBLEM.
    Genius:
  • 1,122 Answers
Tale your cold water hose off and clean out the water valve screen,if this does not work replace the water valve as the soliniod is not opening all the way ,let me know more-mike
Posted on Oct 11, 2008
  • 1,543 Answers
Turn water cold water valve off by hose. Unscrew hose from both ends. Clean out filter inside the end of the washer water valve where the hose was connected to the machine. Check to make sure there is not a screened washer in either end of the hose which may also need cleaning. Reattach and turn water back on.
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Only takes on cold water will not take on hot when you disconnect pipe hot water runs through so supply is ok
If it is a hot and cold fill washer with 2 seperate inlet hoses, and no hot is entering, then either the hot inlet valve is faulty, or the valve is not getting an electric feed to it.
Make sure that the programme you select is ahot prog, as many of the programmes are3 cold fill only.
Mar 28, 2010 | Hotpoint WMA58 Front Load Washer
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Please rate my solution.
Thankyou.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
GE WBSE2090A Top Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
