Question about JVC TH-M45 System
Help i hooked up my jvc th-m45 and it plays the dvd but no picture on the tv. i tried everything. i looked in the manual but nothing. can you help me
  • 10,594 Answers
What video out put you connected between JVC player and TV ?
Look at back of your JVC player for Video out (yellow color) pin, hook RCA cable there and plug it to Input-1 or 2 in TV.
Now select AV 1 or 2 (what ever you hooked) in TV by remote and hopefully picture will in TV.
need further help, let me know model number of your TV.
Posted on Oct 11, 2008
Why can't we get the sound to work by hooking the DVD player directly to the tv?
The JVC system is designed to output audio only via the speaker terminals at the rear of the system. There is NO provision to send audio directly to the TV from the system.
Page 14 of the manual (link provided below - free to download) details the connections available to a TV. These connections are limited to three types of connections: 1) "Video" for standard TVs which is "good" 2) "S-Video" for TVs that have an S-Video input jack which is "better" (both #1 and #2 are considered "composite" types).
The third type is called "Component" which is used for TV's that are capable of "progressive scan" video input which is "best" for the system. Notice that the jacks on the DVD player are labeled "Y", "Pb" and "Pr", not "Video", "Left" and "Right". This type video signal requires the use of three cables - they do not send audio as you may be used to see on all but the newer TVs. TVs capable of displaying "progressive scan" video have a better looking picture when using these jacks. Incorrectly connecting the video from the DVD to the TV audio inputs (Left & Right) will likely result in noise or hiss from the TV speaker.
To recap - audio can only be played through the JVC system's speakers. Use the highest quality video jacks that BOTH your TV and the DVD player supports.
I hope this was Very Helpful and enjoy your DVD and TV!
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Dec 21, 2009 | JVC TH-M505 System
JVC TH-C30 dvd movies skip
Check your formatting on the DVD recorder, you need to finalize the disk to be playable on "any" player. That should solve the issue. Your JVC is looking for specific code as it reads the disc, when it's missing or not understood by your JVC it will either stop play or skip over it's interperated missing info. Hope this helps
Jun 23, 2009 | JVC TH-C30 System
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
Connecting an Ipod to JVC TH-M45 System
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
Apr 20, 2009 | JVC TH-M45 System
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
JVC TH-C5 DVD plpayer....no color when playing DVD's, but color
You might have the connections wrong. If there is component in on you tv(red,green,blue) then use the for the best picture. Other wise use the yellow composite video out to the yellow video in on your tv
Dec 12, 2008 | JVC TH-C5 System
JVC TH-M45 DVD Problem
its not the direct tv. i had the same problem before mine got all messed up. all i had to do was go into my dvd menu and select playback and turn it off
Dec 28, 2007 | JVC TH-M45 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
No color picture
Have you looked at the menu to see if it is an international system? If you have more picture posibilities than NTSC you may need to make that selection. Terry
Sep 03, 2007 | JVC TH-C50 System
JVC TH-M45 System Logo
152 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
