Question about Compaq Presario Notebook
Battery does not charge
Battery will not charge while the computer is turned on with AC adapter connected. It will only charge when PC is turned off and then only intermittenly.
Have a Toshiba M35series laptop. Same problem. With AC connected battery will only discharge and will eventually discharge completely. If I turn off the PC or put it in hibernation it will charge, but only intermittently. Swapped out the power supply thinking it might be the connector but the new supply had the same issues as the old one. Thought about taking the battery out completely to see if it will run on AC only but have not tried this yet. Battery seems to discharge fine once it has been charged so I have tentatively ruled that out as the problem. I have same exact prob,what i think is happening is the heat that is being blown out is overheating the battery.
  • bucky19103 Oct 12, 2008
    both components work so it might be the third.if it is my options are limited since my warranty has just ran out.
  • 84 Answers
Hi Bucky,
Regarding the issue you are having there are 3 possible problem here. It's either the ac adapter, the battery and the motherboard of your system.
To determine the cause of the problem you may try the following steps below.
1. Try turning on your system using the ac adapter only afterwards try using the battery.
2. Try connecting the ac adapter to a different power outlet and check if that could cause a problem as well
2. If the system works with both component then it could be an issue with the system board. If this the case you might need to call your computer manufacturer and check the latest version of BIOS you have. check also if the system is under warranty for part replacement.
Keep me posted.
Posted on Oct 11, 2008
  • Jeff R
    Jeff R Oct 12, 2008
    Try to check if you can update the BIOS of your system. Let me also remind you that if the BIOS update is not properly installed this could cause a major problem with the motherboard. You may encounter an issue in which your computer will not turn on anymore.
    Thanks. keep me posted
How long for battery recharging D610 ?
when the computer is turned off, the AC adapter charges a completely discharged battery to 80 percent in about 1 hour and to 100 percent in approximately 2 hours. Charge time is longer with the computer turned on. You can leave the battery in the computer for as long as you like. The battery's internal circuitry prevents the battery from overcharging. So About 2 to 3 hrs
When you connect the computer to an electrical outlet or install a battery while the computer is connected to an electrical outlet, the computer checks the battery charge and temperature. If necessary, the AC adapter then charges the battery and maintains the battery charge.
If the battery is hot from being used in your computer or being in a hot environment, the battery may not charge when you connect the computer to an electrical outlet.
Jun 06, 2014 | Dell Latitude D610 Notebook
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Compaq Presario Notebook Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
