Question about Panasonic EY6432GQKW Cordless Drill
I want to clean up drill inside. It si noisy probably because of the dust .
How to take off chuck i ve already screwed off holding screw from this part
Juss take the screw unloose and replace it, if that don't work get another chuck.
Posted on Oct 11, 2008
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
Keyless chuck drill just spins
Some times the selector on top get gummed up with dust, it just needs cleaning. You were right to put it into 1st gear to remove the chuck with a big allen key, you get more resistance in the gears.
May 30, 2012 | Makita Drills
Does a Dewalt 106 have a set screw?
Dewalt's DW106 does not have a set screw inside the keyless chuck to hold it on. This means the chuck was put on with enough lok-tite and torque to keep it on under most circumstances so getting it off will not be easy. If you're using the allen wrench-in-the-chuck method, give it a good firm whack until it breaks free.
Feb 14, 2012 | Dewalt Drills
I have a makita dp3720 drill, i can't remove the chuck. what gives
Not the chuck apparently, This could well be reverse threaded, many drills are, some aren't. There is generally a screw in the bottom inside of the chuck and then the chuck itself can be threaded on.
Jun 25, 2011 | Drills
Need to replace chuck
Not entirely familiar with this model but most chucks are secured by a screw inside the chuck. Open the the chuck to its fullest aperture and look inside. There should be a centre screw ... it will be a left hand thread. Remove the screw. Hold the chuck firmly, reverse the drill. The chuck should unscrew from the shaft. Installation is a reversal of the removal procedure.
Mar 19, 2010 | Hitachi 12v 3/8" Driver Drill Kit with...
I have a DC900 dewalt drill and the chuck requires replacing is there an easy way to remove the chuck ?
Open the chuck as wide as it will go and then remove the machine screw from it,it's down inside the chuck.Now,put a 5/16 allen wrench in the chuck and tighten it.Hold the drill with the chuck away from you and hit the allen wrench with a hammer,with the wrench to your right and making the hit drive it downward.Spin it off with your fingers from here,hope this helps.
Jan 29, 2010 | Dewalt DC900KL Heavy - Duty 36 - Volt...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Having trouble removing keyless chuck from 18V DC759
Inside of chuck you have a screw, remove screw then tighten an big allen wrench into chuck, short side in, then hold drill and hit allen wrench with a hammer quickly, should break chuck free.
Jun 19, 2009 | Dewalt 18 Volt Compact Drill Kit
Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
May 19, 2009 | Black & Decker Drills
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Panasonic EY6432GQKW Cordless Drill Logo
286 people viewed this question
Top Panasonic Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
