Question about HP Computers & Internet
TrayApp wants to be installed after booting up computer
  • HP Master
  • 4,338 Answers
Go to start>run> type in msconfig> see if there is an entry for the TrayApp, if there is unchek the box next to it.
Do you have a multifunction HP Printer?
Is so stick in your cd and try to re-install
Also:
Do you have Novell on your PC:
trayapp.exe is a Novell iFolder belonging to Novell iFolder from Novell, Inc.
Seems like most applications have a "TrayApp" installer, hopefully the above will help you.
You can go into the registry and find it, but try this first.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 11, 2008
Tray App msi repair
When you get the error for missing trayapp.Download full feature software and drivers from hp.com. After extracting the downloaded file. Go to your my document's folder. Click tools, go to folder options and make sure to enable "show hidden folders". On the missing trayapp error message, click browse, go to my computer, go to disk drive C:, go to user and document settings, open the folder that has your login name, look for application data > local > temp > open a folder named 7z345 or any folder that has 7z for a file name.. open setup > open trayapp > then click trayapp.msi and click open.. a long process but that should solve your missing trayapp problem.. if you need help, i suggest you call hp
Dec 28, 2013 | Acer Aspire 5735 Notebook
Product assistant
remove printer from the com and then give add device. If still problem exists, connect using USB
Nov 13, 2013 | HP Photosmart C5280 Printer
How to fix Trayapp.msi missing problem
Do you have the installation CD?
If so here is how to remove it..
1st Insert the disk into the CD-ROM.
2nd With the message displaying trayapp.msi is missing click the browse button
3rd - Select the cd-rom drive click/ open the setup folder, then open the trayapp folder.
4th - select the trayapp.msi file and double click on it to open it.
5th - this should return you to the install wizard and finish walking thru it.
if you do not have the disk..
download the software program from HP's website:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=445197&lang=en&cc=us&prodTypeId=18972&prodSeriesId=445194&taskId=135
Select your operating system.
Click on Software or scroll down to software.
Download the correct software based on you region.
Then un-install the existing software program, reboot your computer.
Then install the software you just downloaded.
Oct 21, 2010 | HP LaserJet 2840 All-In-One Printer
Hello! I have an Acer One model AspireOne ZG5. I am getting a TrayApp error message that says that the TrayApp.msi file can't be located. I have done a ull search of the HD and can't find it. The Acer...
This problem is related to the HP Imaging software that came with an HP product. It might be a scanner, printer, camera, or a multi-function printer. Sometimes the software gets screwed up so that it asks for this photogallery.msi file.
One fix that has been discovered for this problem is to place the CD that came with your HP product into the CD-ROM drive before you turn on your PC. When you turn it on, and Windows starts up, the installation program should recognize the CD and automatically find the trayapp.msi file, and the problem will be solved.
If it does not find it automatically, navigate to the folder on the CD called TrayApp. There, you will find the elusive TrayApp.msi file. Click on that, hit OK and the Imaging Monitor should extract the trayapp automatically. One reader has told us that he found the file on the CD in \Setup\trayapp\trayapp.msi
Sep 05, 2010 | Acer Aspire 5735 Notebook
Everytime I start my computer, I get a error message saying windows installer cannot find trayapp How do I fix this annoying proplem?
Run msconfig in run window and choose the startup option and choose the file trayapp and remove the tick and apply it. or you can disable all of them and apply and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 24, 2010 | HP Office Equipment & Supplies
I purchased a refurbished Samsung monitor SuncMaster 2233. It came with no instructions or installation disk. It is asking me to install the "TrayApp" disk
TrayApp isn't related to the Samsung, it's part of the HP printer driver suite. If you have an HP printer, then put in the HP driver CD when it asks for the "TrayApp" disk and you'll be all set.
Jan 09, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
I keep getting a message saying tray app installation incomplete please insert cd. problem is I don't know which program did not completely install and this message won't go away
There are 3 step to repair trayapp.msi error
If you got trayapp.msi error then there is a 94% chance that your computer has registry problems. To repair trayapp.msi error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair trayapp.msi error.
Here are the url of Perfect Optimizer:http://www.fixerrorsafe.com/ttfix-trayap
Nov 13, 2009 | HP Pavilion dv9000z Notebook
TrayApp keeps trying to install when computer is started
If you have downloaded the software from web and if you have installed it then
just click on run and then Type %temp% and hit enter
look for a folder name starting with 7z
open that folder
go to setup folder
go to trayapp folder
and then repair the trayapp.msi file by doing a right click on it and i am sure this will do
Nov 01, 2009 | HP Office Equipment & Supplies
My HPG7035EA freezes just after I log onto windows
You can try the computer without Windows by booting from a Linux Mint USB drive. Look on ebay.
If it works fine with this then Windows has a problem.
If it locks up on Mint then the computer hardware has a problem.
The usual problem with laptops is overheating due to a blocked fan.
Apr 28, 2017 | HP Pavilion dv6000z Notebook
I need to get rid of TrayApp installer. How can you help me??
Insert the printer CD to the PC, close the window that opens automatically.
Open My computer icon,locate the CD\DVD drive and then right click and then select Explore, that would show CD contents, Open Setup folder, in the setup folder open Folder named Trayapp, in that folder you have a file named Trayapp.msi, right click on that trayapp.msi and then select the option repair, restart the PC and then check for the error, any clarifications please comment.....
Oct 01, 2009 | HP PSC 1315 All-in-One Printer
Computers & Internet Logo
349 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
