Question about Google Computers & Internet
Printing from google program
Don't know how to send file to printer
    Problem Solver:
I DOWM LOADED THE NEXT GENERATION FROM TWO TOO THREE WHICH CARRIES THE PRINTER PROGRAM
Posted on Oct 12, 2008
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Tm u220 java
Are you printing from inside a java program (output) or from a java program editor.
Use the command to Open an output file, have all your output sent to the output file, close the output file properly before you exit the java program. After you finish send the output file to the matrix printer as you would with ASCII file. If the printer is installed properly, your OS should know where to send the output.
Dec 23, 2013 | Epson TM-U220 Matrix Printer
The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
Can you send me a "print to file" of the failing document.
At first blush it can be either of two things.
1) The preceding print job did not properly clean out the printer's memory.
2) The new print job, has data or a busted escape command in it that is being treated as printable data.
Send the print file to don.farr@hotmail.com and I'll read through the document header to see what's going on.
Don
Mar 02, 2010 | Dell 1720dn Laser Printer
Im trying to print an envelope using a Dell 3100cn. Im driving the printer with a mac. and cannot get it to print
I'm not familiar real familiar with the Mac OS but, the printer needs to be told to switch to and envelope. This is done by inserting a printer control code into the datastream when the envelope is needed.
I need to know what type of datastream the printer is expecting. i.e. PostScript, PCL or PCLXL.
If there is any way you can generate a "Print File" and send it to me I will be glad to read through it and see if I can spot the failure.
Send the file to don.farr@hotmail.com.
I do not charge any fees for reading and determining the failure if I can find it for you.
Don
Feb 16, 2010 | Dell 3100cn Laser Printer
The printer cannot be set to a page length when printing from a dos program. The page length is incorrect but changes with every print even though the same file is printed
Prints from DOS programs do not have a "page length" setting of their own, nor do dot matrix printer have a page length of their own.
Page feed is achieved by sending a special control code (^L), and the meaning of ^L can be set through specific escape codes that the DOS program has to know.
My guess is that you need to tell the DOS program the page size in lines or inches, and maybe instruct it to send a page feed command after each page.
You can try directly programming the printer, but if the DOS program is sending out the wrong codes, this is not going to help. Anyway, here goes. Good luck!
http://www.masondesigns.com/staging/dhl/printer/lasernet/turboset.html
Feb 01, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
FILE IN QUE, WILL NOT PRINT
What kind of printer are you using?
If you are trying to print a PCL PC-XL or PostScript file, go into the printer driver and click the "Print to File" box. Then send the print file to me at don.farr@verizon.net. I can look at the file with some lab tools that I have and see if I can find the failure.
You can cancel the print job that is active in the queue by double clicking on the printer icon (lower right of the screen) Then highlight the print job and select cancel from the menu at the top of the queue box.
Don
Nov 20, 2009 | HP Office Equipment & Supplies
Pcl xl error subsystem: KERNEL error: IllegalTag
Why not just that the printer is broke?
Please I need a lot more descriptive information before I can help you.
Would you consider sending me the original document and a "Print to File" of the document. I will also need to know where in the printout the error occurs.
I can run it through some of the tools I have and see if I can spot the failure.
Please send the files to; don.farr@verizon.net. I will let you know I have them and get a quick look at them to see if it something simple.
Don
Oct 22, 2009 | HP Color LaserJet 4600n Printer
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
Oct 19, 2009 | Savin 9935DP Laser Printer
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Jan 16, 2009 | Lexmark Optra S 1855 Laser Printer
Computers & Internet Logo
21 people viewed this question
Top Google Computers & Internet Experts
Robet
Robet
Richard Solanski
Richard Solanski
Level 1 Expert
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
