Question about HP DeskJet 722c InkJet Printer
My DeskJet 722c started to leak ink on bottom
I love this printer and know it is old but it is the best printer HP ever made.
Wy all the sudden has it started to leak ink on bottome and I notice I have to turn it on every time as it is not coming on when I turn on computer anymore. Any help or finding me a new HPDeskJET 7222 c would be helpful.
RVCAMP209@aol.com
VERRON
  • 267 Answers
Are you using off brand ink? Try using genuine hp ink and look for updates for printer.
Posted on Aug 02, 2017
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
Sounds like your priming station is full nothing you can do it would have to be replaced and that job will cost you it is a pain and time consuming
  • 26 Answers
SOURCE: HP DeskJet 722c orange ink light flashing
Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
Hope this helps
Posted on Mar 28, 2008
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32 bit version of Windows 7 you can add a driver using the following: go to the Devices and Printers folder, Add a printer, Local printer, LPT1: (or which ever parallel port the printer is connected to), select the Deskjet 720c driver. You may need to click on the Windows Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
Posted on Jan 05, 2010
komguy
  • 2306 Answers
SOURCE: I have just replaced the color ink cartdrige in my
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Posted on Jan 08, 2010
rjblittle
  • 54 Answers
SOURCE: DeskJet 960c InkJet Printer: where do i find my ink level for hpdeskjet 960c?...
us the utility to choose tools, service my printer, and click the tab with the ink levels on it.
Posted on May 18, 2010
  • 1705 Answers
SOURCE: Why can't I see the ink levels on my computer
You may have to update your printer drivers, try the HP website, follow links for downloads and support. Enter your printer model and operating system as you go. See if there's a driver update for you.
Posted on Nov 23, 2010
I recently bought an HP deskjet 810c at a yardsale-- I already have a HP deskjet 722c so I am familiar with the design. The printer seemed to react ok when I powered it up (cartridge came to the center...
Hello cmcclung147
You certainly didn' t mess up , I can assure you .
Generally , with power of and gently lifting the carriage and manually moving it from left to right and/or vice versa , plugging power back on , solves the problem . I succeeded that way with my 930C . Should work with your device .
Good luck !
Best regards ,
fanaudi .
Apr 28, 2011 | HP DeskJet 940c InkJet Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Drive belt for ink cartridge holder shredded
You could take it to a certified HP repair center, but as cheap as printers are these days, it may be more cost effective to just buy a new one - unless your just really attached to your old printer! Good luck!
Mar 27, 2010 | HP DeskJet 722c InkJet Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
Tiny print
I have a two printers, a Dell and a HP, both had the same small printing problem. I am not a computer wiz by no means, but I went into the printer settings and switched to "Factory Settings" for both machines and it fixed the problem. Hope this works for you.
Oct 17, 2008 | HP DeskJet 722c InkJet Printer
Hope this helps
Mar 27, 2008 | HP DeskJet 722c InkJet Printer
Won't print
Clean the ink cartridge maybe sticky on the ink outlet. sometimes refill ink don't work because that problem. some people soak the the cartridge in lukewarm water and clean it. other work and some other don't. so next time do not refill ink to way from this issue. thank you very much.
Jan 25, 2008 | HP DeskJet 722c InkJet Printer
Hp deskjet 722c printer software free
Click on the link below. http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=deskjet+722c&submit.x=3&submit.y=7
Oct 02, 2007 | HP DeskJet 722c InkJet Printer
Printer problem
You'll need to clean the encoder strip, encoder wheel, paper feed rollers and the carriage rod (where the cartridges ride -plus lube this) and cartridge service station. If you can't figure out how to do this, you'll need a tech that knows how. It will get pretty involved and I would recommend getting a new machine because they have come down in price and you could replace this for very little.
Jul 27, 2007 | HP DeskJet 722c InkJet Printer
Problem with ink cartridge
Take a look at www.fixyourownprunter,com Also Tech support at HP
Jul 02, 2007 | HP DeskJet 722c InkJet Printer
HP DeskJet 722c InkJet Printer Logo
200 people viewed this question
Seeker5211
Seeker5211
