Question about HP Compaq nx6110 Notebook
USB devices (not recognized)
I have troubles with USB devices. Mouse works just fine, but both my web cams can't. I have installed them fully, but when I connect cam I get the message 'web cam is not connected'. Help!
I don't even know what USB ports I have (1.0 or 2.0). Where I sould take a look?
    Novelist:
    Scholar:
  • 84 Answers
Hi Hanna,
You may try to uninstall and reinstall the driver of your webcam. You may need to check also if the driver application is compatible with the operating you are using. Most of the new system we have now are operating in 2.0 USB port drivers.
If your webcam driver is compatible only with windows XP, then it won't help you resolve the problem if your system is operating in Windows Vista (new operating system for most new system).
Please clarify also the type and model of the webcam you are using. keep me posted.
Thanks.
Posted on Oct 12, 2008
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
Hello, Just now my Asus notebook n80v series laptop has stopped recognizing my usb mouse. This mouse has worked fine for months, and even my older mouse (which worked without trouble on this laptop for...
If other USB devices are woking fine, it means that the USB ports on the system are OK. The issue could be with the mouse. So, I suggest that you should check the mouse by connecting it on some other system. Also, try another mouse with your laptop and see if it works.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 21, 2010 | Computers & Internet
How do I hook up my new laptop webcam to the system
If it is an external web cam , it should have a USB connector . If so , simply plug it into your laptop from your desktop..(after windows is fully loaded and your computer is in a "calm" state .) Your computer should recognize the web cam and will attempt to load drivers for it . If your web cam came with a installation disk , install it first . Select installation or setup from the CD menu and follow the directions to install the web cam .
Nov 19, 2010 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
Mouse does not work when used under xp. Followed installation guide but mouse appears inoperable. Mouse batteries are good and usb receiver working but no cursor movement with mouse. Attempted several...
I called Dynex customer support and they walked me through the troubleshooting process. It turns out there was a problem or conflict with one of my usb ports. The port recognizes my flash drive and other usb devices but not the mouse. I tried using the other two remaining ports and the mouse was recognized and works just fine.
Feb 16, 2010 | Dynex Wireless Optical Laptop Mouse...
Recently when i plug my web cam into a usb port my usb mouse quits working. When I look in device manager it does not show the mouse as being installed. As soon as I remove cam the mouse reappears. Have...
dont use the front usb sockets sir use the back side motherboard direct usb connections your problem will solved , dont forget to vote . Thank you
Nov 03, 2009 | Computers & Internet
USB Mini Optical Mouse - Model: M409 company Enter not recognized
go to device amanger then uninstall all usb drivers from computer then restart the computrer then it autoinstall all usb drivers.
tehn connect your usb mouse cable to computer try all usb port then if problem arise then your mouse usb chip has issue.
Thanks for using fixya.
Please rate solution if it helps.
Jul 24, 2009 | Computers & Internet
Window doesn't recognize any device such as the web cam,mouse,printer . it was work before
try to update your machine's bios to its latest version then restart your machine. if it still doesn't work then try to re-intall devices of your machine such as web cam, mouse and printer.
Jul 01, 2009 | Computers & Internet
Icontact web cam will not turn on
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 11, 2009 | Ezonics iContact Webcam
Malfunctioning webcam
What you need to do is update your usb drivers. Follow instrution below.
Firstly re-insert your web cam.
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
If your are using windows 2000 use the one below
WindowsXP
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
061027085005_16154.png Follow the steps to update the USB driver
Feb 09, 2008 | Philips SPC610NC Webcam
HP Compaq nx6110 Notebook Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
