Question about Black & Decker B2300 Bread Machine
No mixing when I start the machine, there is no mixing action even after the first 15 minutes.
  • 3 more comments
  • Anonymous Oct 13, 2008
    I have the same problem, the mixers never move during the entire cycle
  • Anonymous Oct 26, 2008
    I have the three pound bread maker and I just tried it today and the paddles don't move. The motor is working, but the paddles aren't turning and it sounds terrible!
  • mtl4096 Jan 14, 2009
    I have the same problem on B7D B2300
  • ritacookie Jan 20, 2009
    My machine appears only to work on the rapid bake settings. Doesn't want to start on Basic(1) or whole grain (5). I thought maybe I was being impatient but after taking a shower and going to the store it still had not started.
  • bruinmobile1 May 11, 2010
    hi i was wondering where i could get a manual for a b2300 bread maker you can leave message at bruinmobile1@hotmail.com i live in grimshaw alberta canada thanks hope to hear from you soon
Sometimes it depends on the temperature of your ingredients. We have had a B&D machine for over 13 years now and it makes wonderful loaves of bread and rolls and pizza dough...you name it.
However the new B2300 was on sale at half price this week and we decided to get a new one because of the extra sizes it makes.
I expect this one works the same as the old and it takes a while to "think" about what it is doing. I hope your loaves still turned out nicely. But sometimes there IS a bit of experimentation to get the mixes just right.
While I am here, I will give you a tip. If the paddles get stuck in the container, do NOT try to force them out of it. Instead, put some warm water in there and just forget it for a while...maybe an hour and they will just lift right out as slick as can be. Otherwise you can break those suckers and they are a devil to get hold of new ones after a year or so.
Posted on Nov 29, 2008
Soft serve machine freezing solid
POSSIBLE CAUSES• Mix hopper is empty, freezing cylinder starved for mix.• Mix in hopper contains ice particles, mix feed tube clogged.• Machine turned too cold
ACTION REQUIRED• Add mix to hopper. Put machine in wash mode to help thaw freezing cylinder.• Pull mix feed tube to fill freezing cylinder. Replace mix feed tube and put machine in wash mode to help thaw mix in freezing cylinder.• Follow manufacturer's recommendation for the proper temperature for the mix being used.
Apr 12, 2013 | Ice Cream Makers
When I plug in the machine I get at dash and 2 zeros. The directs say I should see 3. I cannot get it to do anything else. Do I have a lock somewhere?
without any ingredients in the pan....after plugging in your machine,,,,push "select" button.... choose program #1.....this is the basic white bread program....now push the "start" button... your machine should start mixing either right away or within 15- 20 minutes...if it does then your machine is functioning properly.....
May 09, 2011 | Breadman Kitchen Appliances - Others
My Toastmaster TBR2 breadmaker does not mix and knead when started. The pan is positioned correctly, it is in P1 and the countdown timer is on 3:00. It makes a tick-tick noise but nothing happens. Why?
In cold weather many bread machines have to warm up for 15-20 minutes before they start. The clicking you hear is the heating element warming up.
Jan 22, 2011 | Toastmaster TBR2 Bread Maker
I have a Panasonic SD-YD 150 that I bought at a church bazaar. I looked brand new, so I took a chance and bought it. Well, nothing happens when I press the START button. The red light is lit and the...
There may be nothing wrong. 4 hours is probably the length of the bread program you chose. All bread machines do that. After about 15 minutes your machine should start the kneading process with a slow pulsing mix. Some machines and programs don't do anything for the first 15-20 minutes. Whole wheat recipes especially have a built in delay before any kneading begins.
Nov 22, 2010 | Panasonic SD-YD250 Bread Maker
When you want to make only dough the dough senting does not work
The dough setting has a 20 minute delay before the paddles start to move. The manual say's "for most programs, there will be a 15-minute delay before mixing cycle begins"
Nov 07, 2009 | Black & Decker B2300 Bread Machine
My bread machine will not turn on. There is nothing wrong with the electrical outlet.
For the B&D All-in-one, on pg 12 it says "Press the 'start' button. For most programs, there will be a 15-minute delay before mixing cycle begins."
When I'm impatient, I use one of the cycles that does not have a delay (e.g. Rapid Bake 2
Oct 15, 2009 | Black & Decker B2300 Bread Machine
My bread machine is not mixing at all even afater a whole cycle 1 hour and 50 minutes any advice (black and decker 2300)
The same thing has happened to me... So the solution is put the machine on # 8 dough, and cook it in your own oven.. I found the #1 did not mix. The dough was all bumps...
Sep 16, 2009 | Black & Decker B2300 Bread Machine
Machine won't start
It is normal for the bread machine to 'just sit there' for a numbr off minutes before it starts to mix; 15 min - 2 hours depending on recipe and room temperature (see page 13)
Jan 12, 2009 | Panasonic SD-YD250 Bread Maker
Black & Decker B2300 Bread Machine Logo
241 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
