Question about Ricoh Aficio 1035 Copier
Line on page using ARDF
A line appears on the lower right one-quarter of the page when the ARDF is used for automatic feed. The line is not present when not using the ARDF. I have cleaned the glass several times and cleaned the wheels on the ARDF. Problem persists.
  • mammol Oct 11, 2008
    Cleaned it three times. I even took it apart and cleaned both sides of the small glass and used canned air to blow out the area. Thought I had it. Then I notice that there is a 1 of 2 written in this corner of the page I was copying and on the copy it reads of 2. The 1 was missing. So the page is not lined up as it goes across the plate. That's apparently the problem. Wonder if I need to change the wheels. Any any additional help would be great. Thanks.
    Scholar:
  • 62 Answers
Good news!! This should be an easy fix.
If the line appears only when you are using the doc feeder, and it looks like a straight line that you have drawn with a ruller, then it is on the glass. Not the large glass where the copy lays, but the narrow glass. Make a copy using the ARDF, paying close attention to it's orientation (which side is up and which is down). Then, take the copy you made and lay it next to the narrow **** glass in exactly the same direction as it went through the feeder. Wherever your line is, there is something on the glass in that spot. Take your thumb and rub with a good bit of pressure in this spot. You might not see anything, but trust me, there is something there. It might be as small and transparent as a spot of ink. A flashlight will help. You might also try using rubbing alcohol on a soft cloth to clean it. Hope some of this helps,
Chad
Posted on Oct 11, 2008
What could cause norstar m7208 phone to not receive incoming calls
If you have lines appearing on your phone and they don't ring you need to program lines to ring. This type of programming is done from a M7310 phone. Page 323 of this manual shows how to program this on a NorthStar MICS Ver 6 phone system.
http://pdf.textfiles.com/manuals/TELECOM-F-R/Nortel%20MICS%20System%20Installer%20Guide%206.1.pdf
Enter the programming mode : Feature **266344
Password:266344
You will have 4 programming buttons on your phone, normally the 2 top left and 2 top right of the 2 vertical rows.
top left = move up one level
lower left = back
top right = select
lower right = next
once you enter the programming mode press next to "Terminals and Sets"
press select
enter your extension number
press select
press next to "Line Access"
press select
press next to "Line Assignment"
press select
use the next key to go to the line you want and use the soft-key below the display to change it from "Appear" to "Appear and Ring"
May 05, 2015 | Nortel Norstar M7208 Telephone
Just ink line on right center of page on auto feed only
It would be nice to know what kind of printer this is!!!
Normally with that problem the glass has to be cleaned.
Clean the glass that is used by the Automatic Document Feeder.
Normally it is a thin strip of glass. It is dirty.
Jan 11, 2011 | Office Equipment & Supplies
AUTOMATIC FEEDER LEAVING LINE ON SCANNED PRINT-OUT
clean the thin DF glass strip on the left side with a damp cloth
Mar 15, 2010 | Brother MFC 6490CW InkJet Printer
When I use the automatic feed a blank line appears in t
BLANK or BLACK?, if it's Black, clean the SCANNER GLASS.
Aug 05, 2009 | HP LaserJet 4345mfp Printer
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Automatic feed gives a white line in copy or scan
Although this problem would normally show as a black line on the copy, it's quite possible that there is something white (i.e. a piece of tape or paper) stuck on the scanner where the page feed passes through. Clean this area carefully with a soft cloth.
Jun 01, 2009 | HP LaserJet 4345mfp Printer
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Kodak I260 paper tray not lowering after tray emptied
The Kodak i260 has a fixed Paper Tray and does not automatically move up and down?????
Oct 05, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
Black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Feb 28, 2008 | Canon ImageClass D880 Copier
Ricoh Aficio 1035 Copier Logo
64 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
