Question about Garmin StreetPilot c310 GPS Receiver
Problem with my garmin c310
Hi!i deleted everything from my sd card and now i don't know what to do...does anyone knows how can i fix my garmin...thanx
  • Anonymous Apr 12, 2009
    hi deleted every thing from memory card
Garmin do send out update DVD maps for certain products. If it was an older unit, you maybe entitled to a free update. Simply get the Mapsource DVD. upload the maps to your PC and then transfer onto your Garmin unit.
Alternatively is to buy the DVD, which would be an advantage as it may offer additional maps to what you already had...ball park €60-70 Euro I think...Check the Garmin site...
Posted on Oct 28, 2008
What type of memory card do i use for kodak easy share c310 camera
The C310 works with MMC and SD cards. MMC cards are nearly obsolete and hard to find, so I suggest SD cards. Be sure you get an SD card, 2GB and smaller. Larger cards are actually SDHC cards and will not work in the C310.
Aug 22, 2011 | Kodak Cameras
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
I am trying to download an update on my Garmin but I get the response, " Your device does not have the recommended space for the region you selected." I am just needed the US. How can I make more space...
Hi Jwatkins99,
Depending upon the model of your Garmin, these tips should still apply. If your unit uses SD cards for maps, try deleting all other country maps, including Canada and Mexico, if you don't plan on going there. You should do a backup of the SD card data if possible. Use the computer for this. I usually backup the maps then delete some of the larger maps on the opposite coast or side of the country...if I don't plan on visits soon.
If you have external data in your units main memory, try clearing some of that out using your USB hookup to your computer. If your maps are on the main memory, be careful not to get into those Folders (Directories to us Nerds) and inadverently delete the software programming for the GPS unit.
Also, if you're using SD cards, your unit may allow you to use something larger than a 2-4 GB card. Then you should have plenty of memory.
Let me know if this helps. Thanks.
Regards, Bill
Sep 17, 2010 | Garmin GPS
Hi I have a kodak c310 camera & i keep getting
Your camera is only supporting SD/MMC Cards (up to 1 GB).
The card that you currently have might be faulty or not compatible. Please try another card.
Jan 15, 2010 | Kodak EasyShare C310 Digital Camera
I have a kodak c310, trying to format the card and it keeps saying memory full format card, so i format and it comes up FILESYS ERROR e00100, but it's a new card?
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Oct 21, 2009 | Kodak EasyShare C310 Digital Camera
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express.
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
Trouble Formatting New SD card
try to format using a card reader through PC...
Feb 10, 2009 | Kodak EasyShare V803 Digital Camera
2 gb sd card
Hey Guys yes I am from South Africa Just bought the SD 2 GB ScanDisk sd card - Same Thing
Pathetic to say the least!
Anyways - Thanx for the comments what i have learned from this is that its not just ME with the problem, and I must say I feel better!
Kodak C310... well you cant compare it with the big boys...
Ps: formatting the card in your pc does not fix the problem with the camera, I tried it.. The card works fine on my Garmin
Jun 05, 2008 | Kodak EasyShare C310 Digital Camera
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c310 GPS Receiver Logo
223 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
