Old and new battery do not seem to take a charge.
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
SOURCE: Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Yes, they do have somethnig built in to detect if you are using a non-Dell battery, ergo you would not receive messages like "Battery cannot be identified" at boot up, and a warning that the system won't charge the battery. It is simply a ploy to ensure users buy Dell batteries at their inflated price. It's also known as anti-competitive behaviour in the business world.
Just so you know, they incorporate the same system with the power adaptor. If you use a non-Dell one, it will state that it cannot determine the power adaptor type and then let you know that the laptop will run slowly and will not carge your battery. Another way to make sure you behave and buy only Dell spares. Incidentally, with the adaptor it knows if it's a Dell one because Dell use the centre pin of the adaptor jack connector to send a 2.5V ID signal to the laptop. The positive and negative of the 19V supply is on the inside and outside of the metal barrel of the jack plug. Internal pin is solely for ID signal.
I'm afraid the only recourse is to purchase a Dell adaptor if you wish for the battery to charge. I'd recommend a second-hand one from eBay. Try to buy the highest wattage one you can.
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
SOURCE: inspiron 1501 wont read blank dvd
download and install the latest firmware and BIOS..you will the latest by version number.
to check you computer configuration go this link and type in your service tag number
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&l=en&s=gen&~ck=bt
