Rank: Guru
Rating: 88%, 3768 votes
The "H E L L O" message is part of the
booting/initialization process of the built-in micro processor of the
RCA DVD Recorder. Just like in a PC, it can also suffer from
crashes/hangs.
Initially, pls try a reset. "
disconnect it from all power and cable sources, leave off for 1/2 hour,
then plug back in and hold the stand by buttons for the remote and on
the machine at the same time"
If the above is not corrective, then you may have to consider a repair, probable areas to start
checking would be:
- firmware, might need a re-flash or update;
- hard drive, might have bad sectors or require replacement.
Alternately, if you are not considering a DIY (
do-it-yourself),
you may have to re-evaluate the options since in some instances, cost
and time of repair may no longer justify having the unit serviced.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
