Home | Frigidaire | (ATF6000ES) Front Load Washer | Washer won't spin in fin...
Frigidaire Front Load Washer
Problem for Frigidaire (ATF6000ES) Front Load Washer
Washer won't spin in final spin out
By harley1964dm on Oct 11, 2008
i have a friidaire front loader and it will not spin out in the final spin would you please help me. thanks
Same Problem
Feb 11, 2009
-   Same thing.....Frigidair Front Load works all cycles fine until final spin and shuts off around 6 minutes each time leaving clothes soaked. Just had a repairman out and it wasn't a clogged pump as many online suggest. They tested the main computer board and found a short....it's going to run approx. $350 and I just hope it fixes the problem....will post if this fixes the problem but I have to wait a few days for part and installation.-   ktrout369
Oct 15, 2008
-   Mine does this as well and it really makes me mad. I can put 2 bath room rugs in mine and it won't spin them. I wish now I had gotten another brand. It says it is heavy duty but it's not.
-   Guest
Oct 14, 2008
-   i have the front load washer and the the machine works great till the final spin the at 7 minutes left it will shut off i have tried what you said about the load to small and added more clothes and have also unplugged the machine for 5 minutes and as well as 30minues nothing seem to work i do not get a message on the control panel is there something else that i cant try.-   sjtmm1964
Oct 13, 2008
-   washer won't spin in final spin -   Guest
Best Solution
posted on Oct 13, 2008
Helpful)
huuum
Rank: Wiz  Frigidaire Expert
Rating: 85%, 645 votes
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Front Load Washer
Questions and Unsolved Problems for Frigidaire Front Load Washer
Do you recommend Frigidaire (ATF6000ES) Front Load Washer?
Answer
Answer
i have a hoover nextra hnl 662 washing machine it will rinse and spin but want wash delay start... (More)
Answer
The water comes in very slow and stops and slow again and hasn't been spinning. We tried everything... (More)
Answer
The drum on my front loader knock when it rotates and appears to be loose. the bearing at the rear... (More)
Answer
My machine willfill up with water and spin both both ways washing, but it will not spin on the rinse... (More)
Answer
My Frigidaire Affinity Front Load Washer sometimes stops in the middle of a cycle. It... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
