Question about Pioneer Audio Players & Recorders
Pioneer cdl 1000 mk2 frozen - Pioneer Audio Players & Recorders
A/V receiver freezes up and has to be unplugged for it to work "almost normal"..
I had the exact same problem with mine. Local repair shop had to replace the main in-put chip on the back of the front panel. Works great now. Cost about $125 out the door.
May 31, 2009 | Pioneer VSX-94TXH
I have a behringer djx 700 and i got an efx 1000, and would really help me if you no how the best way to connect it to the mixer my dj setup is 2x pioneer cdj 1000 mk3 1x behringer djx700 1x pioneer...
ok has the mixer got a send and return phono sockets if it has not the efx unit will have to be wired between your mixer and amp.this is not the best way . what does the efx / effects unit do .
Dec 08, 2008 | Audio Players & Recorders
Pioneer pl 50 turntable it is turning too fast ,there is no adjustment.Is there a solution
I brought my turntable in a repair shop. Don`t know if it will be fixed. If not ,I will use your technical support. thank you Alain
Oct 14, 2008 | Pioneer Audio Players & Recorders
Power won't stay on for Pioneer Receiver Model VSX 3900S
not a permanent solution but this is how i got it working... keep pressing the power button different ways (ie. hard, soft, etc) and when you do get it, dont touch it for a decent period of time, like 15 minutes. Then turn it off and on, it should turn on this time wo a problem and if it does then it souldnt be frozen anymore. Otherwise, if i didnt wait 15 minutes, it would be frozen and if a certain button was pressed or the receiver is moved, it will just shut off. ANother piece of advice, once you get it working, leave it on!
Aug 08, 2008 | Audio Players & Recorders
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
