Question about RCA DIRECTV Satellite Remote Control
Use of TV code 1235 disables remote for directv receiver
I have 2 different RCA Directv universal remotes (one gray, one black/red) and a Philco/Magnavox TV. I know how to use the remotes to select and control different devices.
When I program either remote for the TV with the Automatic Search method or directly with code 1235, the remote can control the TV but the remote is no longer able to control the Directv receiver. I can not program the aux to control the receiver either.
If I reset the remote (by removing the batteries and holding the "1" key), the remote can again control the receiver, but of course it can not control the TV.
Am I missing something? Is there a way around this problem, or is it simply a case of "defective by design"? It is hard to understand why this should happen, particularly when automatic search mode is used!
PS - Using one RCA remote for the TV and the other for the receiver is not an OK answer 8-).
  • 54 Answers
Ok try to use both remotes to set up on one tv.
Posted on Jan 12, 2009
Could you please tell me how to reset my tv? I have a blue screen
What should I do if my TV screen turned black, blue, or gray? print.png Print try this.
Proceed with the troubleshooting steps below only if you're seeing:
  • Black, blue, or gray screen
  • "No Signal" message without the DIRECTV logo
Note: If your TV screen appears "frozen" or you're seeing wavy lines or overlapping images, try this.
Solution 1: Check that your TV is set on the right input
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">Turn your TV and receiver off and back on.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number2_icon.png">Using your DIRECTV remote control, press the TV Input button to cycle through TV inputs (Component, HDMI, etc) until you see a picture. If nothing happens when you press the button, try programming your DIRECTV remote to control your TV Input and try again.
Note: You can also try changing the TV Input using your TV remote.
[img border="0" alt="Image" src="http://www.directv.com/cms2/global/icons/sm_cl_blu__number3_icon.png">If you're still having issues, check the cable used to connect your receiver to your TV.
Still not seeing a clear picture?
Continue to Solution 2.
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/support/answer_center/tech_faq_images/img_screen_off_4.jpg">
Solution 2: Reset Your Receiver
[img border="0" alt="Image" src="https://cdns.directv.com/cms2/global/icons/sm_cl_blu__number1_icon.png">On some DIRECTV receivers there is a red reset button located inside the access card door on the front panel. Press it, then wait for your receiver to reboot.
Note: If you cannot locate the red reset button or your receiver does not have one, unplug the receiver's power cord from the electrical outlet, wait 15 seconds, and plug it back in. Then press the Power button on the front panel of your receiver and wait for your receiver to reboot.
could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-0.jpg could-please-tell-me-reset-tv-blue-i0x50p0fk40mg1d0uyxi2cma-5-1.gif
May 12, 2014 | Vizio L37 Television
Emerson Jumbo Universal Remote won't program Direct TV receiver.
Have you tried doing this:
Press and hold the TV button on the remote till all 4 buttons light up and flash(make sure your TV is on). Once they flash, press the power button, then using the channel up button, point the remote at the TV and keep pressing it till the TV turns off. When it does, press the # sign and that will lock in the new found code.
Hope that helps........
Jul 21, 2008 | Televison & Video
Codes for a rca converter box remote control
Try using directv's :remote control code search engine)search for "Directv remote control programming" enter your device type and it will give you the most recent code for your device
Mar 08, 2014 | RCA Universal Tv Digital Converter Box...
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
Directv remote will not program to rca L42FHD37R. What is the code? I have tried all of the codes given by Directv.
"This TV utilizes new remote control signal codes and may not be compatible with your existing universal remote (e.g. satellite box remotes, cable box remotes, generic universal remotes, etc.). Over time, newer universal remote controls that become available should pick up the new TV codes."
Dec 07, 2009 | RCA L42FHD37 42 in. LCD HDTV
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Remote control code
Those 2 remotes are not compatible with the newer directv receivers
Feb 09, 2008 | Directv D10 DTV Receiver
Jumbo Universal Remote Control
DIRECTV all models 00001, 00002
also use 200-217 from the jumbo hand book good luck
please rate
Dec 24, 2007 | RCA DIRECTV Satellite Remote Control
RCA DIRECTV Satellite Remote Control Logo
227 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
