Question about Motorola Mobility RAZR V3i Cellular Phone
Display settings I have set everything in my phone correctly, I believe, and the exterior display still will not turn off.
I want installer ...
Posted on Oct 17, 2008
Have A 5.0 Studio Blue android phone&my volume is not working on when receiving calls but works on everything else&volume is up in settings,any suggestions?Factory reset erases my apps correct?
I don't believe you need to do a factory reset, Probably the phone call voulme has a different setting control. Check your phones manual for indications. In my LG phone the volume of multimedia (audio and video files) has nothing to do with the phone call volume.
Jun 22, 2015 | Android Cell Phones
"Input not supported" even though it appears to be displaying correctly.
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
Apr 21, 2015 | Planar Computers & Internet
When I connect my Nikon D3200 to an exterior video monitor so I can see the image better for 'Focusing' purposes, it won't display, giving me an error message about not being able to do this with present...
Go to your display settings.. Change over resolution to what the external monitor can display. It also could be the Hrz that may need to be changed so the external to display correctly and that option is also in advanced settings.
Sep 23, 2013 | Computers & Internet
Time on phone keeps changing and doesn't stay when I put the correct tome in...which I shouldn't to do right....its suppose to be automatic but its constantly giving me the wrong time...help please
Your secondary battery located inside your unit which is for correct time display maybe drained. I have the same problem with my phone. After I had it replaced by a technician, my phone clock display is now working nomal. Another option if you don't want your secondary battery replaced is setting your phone to automatically detect your network's time. Go to settings, look for time and date settings and locate the automatically update time or something like that. Everytime you turn on your phone, it should automatically detect and display a correct time.
Dec 19, 2010 | HTC EVO 4G Smartphone
My HTC evo has a rotation problem won't turn back to.vertical how do you fix this
In Sounds and Display, check that the orientation is set correctly. There have also been problems with screen sensitivity. I believe a patch will be coming out soon to address these problems. You could try going to Settings/Display/ G sensor calibration.
Nov 21, 2010 | Computers & Internet
Razr display goes dark
yes i think that in the phone you go to option menu in menu settings in setting displays is the option there you have the option to either turn off the display or choose the interval like 1 minute or 2 minute.
Jan 11, 2008 | Motorola Mobility RAZR V3
Exterior display
get it serviced from the service center. outer display is not meant to be on constantly
Dec 24, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Time display
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
Nov 19, 2007 | Motorola Mobility RAZR V3
Change extension numbers
From the phone dial #66xxx (where xxx is the extension) to turn off that phone.
Then dial *66xxx (with the correct extension) to turn on that phone.
Hope this helps.
Oct 22, 2007 | Avaya Definity 6408D Corded Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
