Question about Acer Aspire 5630 Notebook
Installing new ram
Instructions on installing new 2 gig ram in my aspire 5630/6368 notebook strips?
    Genius:
  • 1,913 Answers
Open back plate of your laptop. then u see on top of battery the ram slot.
fix your ram.into it.
check also there is any other ram?if there is u must check both ram frequency and chip company.
Posted on Oct 11, 2008
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
What is the largest ram i can install into my laptop
Im sure the max ram you can install is 2 gigs. hope this helps.
Dec 03, 2009 | Acer Aspire 3000 Notebook
I have 2 512 ram cards i tried to install a 1 gig card it didn't work and now my computer only sees one of my 512's
you need to pair memory modules. you need to buy another gig of memory and have it paired
Jul 09, 2009 | Acer Aspire 7110-2069 Notebook
I can't get 3gig ram to boot in my Acer Aspire 3680 Notebook
Test the second stick of memory in the first slot. Confirm that the second stick is not a problem. If it works, then you have a bad slot on the motherboard. Oh, and one other thing--make sure the memory stick speeds are compatible. Match the memory speeds where possible. Post back your findings.
Mar 06, 2009 | Acer Aspire 3680 Notebook
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Can't upgrade an Acer Aspire 3000 notebook to 2 gb
Thanks for choosing fixya.com
Your not alone in this type of problem. When it comes to computer (laptop especially) they usually have a "Max allowed ram" most times its listed in the back of the manual in small print. Its a way to keep people buying new computers (if your into the conspiracy theories)
Chances are even a bios upgrade would not fix your problem. Mostly BIOS upgrades add support for new boot options, plug and play support, and fixes to bugs in older versions.
You can check aspires/acers website for updates www.acer.com
If they have an update it will comes with documentation as to what the update does.
Hope this helps you out.
Jei
Dec 15, 2008 | Acer Aspire 3000 Notebook
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Graphics upgrade
As long as you have a open vga, vga e, or pci slot in your computer you should be able to install a new video card. the Acer website says your motherboard supports up two gigs of ram, I am not sure how much ram you are running but if it is under 1 gig I would consider upgrading that also. as far as a graphics card goes get one that has at least 512 mb of its own ram so it dosent pull from your system ram as I am sure your current on-board card is doing. Another couple of hints are: if you are running Windows Vista you they call for 1 gig ram for optimal performance, also it is very important that you un-install any graphics drivers before you install new ones, and when you install the new card read the instructions completely before you do anything.
hope this helps
Carl
Feb 07, 2008 | Acer Aspire L100 PC Desktop
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
Acer Aspire 5630 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
