Question about Sport & Outdoor - Others
Atv will not start
My atv won't start i hit the start button and all you hear is click i tried the pull cord and it is stiff you can't pull it. what would the problem be???
  • jontar9 Dec 01, 2008
    MY atv (chinese made) 4 wheeler, will not start, now. I squeeze the brake lever and push the start button and it just does nothing. No clicking, brake light does not come on, New battery, New spark plug, and New fuel filter. ???
    Problem Solver:
  • 10 Answers
Im sorry but the battery is deffinatly dead. you need to re-charge it or probibly buy a new one.
Posted on Oct 15, 2008
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Will not turn over. replaced solenoid and battery is new. Lights, and power OK. Too weak to pull cord to manually start.
You need to try and find someone to try the manual start, just to rule out anything past the auto switch such as starter. If battery is new and solenoid is new then it's probably either the switch or could even be a fuse in the link.
Sep 02, 2015 | Arctic Cat 2007 400 4x4
2007 polaris hawkeye won't start
If I try and pull start it and it just makes noises tried to jump start it and dose nothing what could it be I bought a new battery but no way of checking if it's charged or not
Jun 26, 2012 | Polaris ATV
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
Atv wont start when electric start button is pushed
Iguess she hosed the machine down ,water may have tracked and drained the battery ,and what you are hearing is the solenoid clicking....try another battery or jumper leads off the car you may be surprised .WHAT EVER YOU DO DONT,I SAID DONT.,RUN THE ENGINE WITH OUT THE BATTERY HOOKED OR YOU WILL BURN THE RECTIFIER OUT!!! AND IT WILL BE UNABLE TO CHARGE THE BATTERY, if the new battery doesn`t do the trick , you are going to haveto follow the clicking by ear until you find where the clicks are coming from let me know PLEASE I also can learn from your experience
Aug 28, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
FRONT DOOR LOCKED
First try to hold down 'end of cycle' for 3 seconds, try door after a minute or so after hearing a click, power shd be on. If not:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Nov 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sport & Outdoor - Others Logo
382 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
