Question about Pioneer DEH-P4700MP CD Player
Put in new car battery, now can't get aux to work
My daughter plays her MP3 player through the Pioneer by plugging it into what I suppose is called a pigtail, and setting the Source to Aux. All was fine until I replaced the car battery, now I can't get the Aux function to come up on the display. It normally comes up by pressing the Source button. I tried reactivating the aux function per my manual's instructions by repeatedly pressing Function, but it won't show Aux, thus I can't turn Aux back on which I believe would make it show up again as an option in Source.
  • chauncey2 Mar 23, 2009
    i have the same problem. i followed these steps, and i can now switch into aux mode, however i cannot hear my mp3 player. i checked to make sure it was playing and turned the volume on the mp3 as well as the head unit up. but still nothing.
    Scholar:
  • 61 Answers
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Posted on Mar 05, 2009
  • scottandtish Jan 21, 2011
    You are THE MAN!!! So stinkin' easy! Thank you!
How do I get the MP3 player to work in a 2007 Nissan Quest?
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
Jul 05, 2014 | 2007 Nissan Quest 3.5 Minivan
How do i connect an aux cord to my head unit
do you have an aux on the front of the unit or the rear??
if on the front, just plug the lead into the head unit, then into your ipod,mp3 player or whatever. then set the unit to read aux on the front, then simply play your device through the head unit
Apr 05, 2010 | Pioneer DEH-P6800MP CD Player
I think an MP3 player can be attached. How is
Just buy a 3.5mm cable to go from your MP3 player to the "Aux In" jack on the front of the stereo. Plug that in and press "play" on your MP3 player and you're all set.
Jan 25, 2010 | Pioneer DEH-P3000 CD Player
How do i get to the AUX function? i'd like to play my mp3 player thru it. Also, what is the hole/plug? in the back of the unit for?
you will need to turn unit off and press the function button for a few seconds this will take you to a settings menu here you can adj the clock, aux imput , sub and rear spk out put and dimmer and other options,the 3.5 jack at the rear is for the connectin of steering wheel controls .
Sep 03, 2009 | Pioneer DEH-P3800MP CD Player
No aux sound
Try going through the menus and finding a place where you can adjust the aux level(volume) on my sony it has to be all the way up to match the output of the radio and cd functions-also my mp3 volume has to be up bout 1/4 to even hear it but when i turn it up it really goes then-i dont know if that helps but good luck
May 21, 2009 | Pioneer DEH-P6300 CD Player
Do i need to buy a cable to run my mp3 player on cd player
Hello jaredsmick,
Yes, you should be able to plug your MP3 player into the DEH-P3700. You will need a cable. While I'm not certain as to what type of output jack your player has, it's most likey a "mini-jack". Here's a link to what it looks like:
http://www.3dcontentcentral.com/download-model.aspx?catalogid=171&id=10185
You'll also need to make sure that the "AUX" source is turned on in the Pioneer. To do this, press FUNCTION repeatedly until AUX appears in the display. Press up/down to turn ON or OFF and the status will be displayed.
Hope this helps.
Apr 22, 2009 | Pioneer DEH-P3700MP CD Player
Problems conecting to pioneer reciever
You will need a 1-to-2 AV Y-adapter. One end will plug into the headphone jack of your mp3 player, and the other end will plug into the red and white audio input of an open slot on your Pioneer receiver. Then change the mode on your Pioneer receiver to correspond to the input jack that you are using. If you plug the Mp3 player into AUX, change the pioneer mode to AUX, etc.
Jun 20, 2008 | GPX MW3837 MP3 Player
Getting it to play my mp3player
I've tried the same thing trying to get it to work without having to buy the aux adapter for it.
You need to buy 2 items to get your pioneer to work in aux.
1. buy the Pioneer auxiliary input adapter CD-RB10
2. buy a wiring harness that has 2 rca inputs on one end and a male plug to plug into your mp3 player on the other end.
You should be able to find these online or even at any electronic stores that have car audio installation as a service.
Jun 19, 2008 | Pioneer DEH-P7600MP CD Player
Trying to hook up mp3 player
they are out jacks and you need to run the rcas to an amp and then run your speakers off the amp your mp3 player should work when you plug it in the front and press source aux unless the front jack is an out only
May 25, 2008 | Pioneer DEH-P400 CD Changer
Pioneer DEH-P4700MP CD Player Logo
535 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
