Question about Corel AE CorelDRAW Graphics Suite 12 for PC
Importing images from the internet to corel draw 12
I need to cut out an image I have found on the internet. I saved it as a jpeg and a bitmap, but when I import it into corel I can see the image, but when I go to export it, it is not there. Do I need to convert it to something other than the above mentioned?
    Sniper:
  • 52 Answers
1st) Go to file new and after a blank page is displayed go to File import and when the import screen is displayed go to "files by type" and select "ALL FILE FORMATS" be certain that you are looking in the folder that contains the jpeg file that you want and select it.
Posted on Oct 19, 2008
How do I paste a photograph into a painting? Every time I copy and paste it only copies a blank image.
Try this. Load the photo into MS Paint and use the select tool to select the part of the image you want to copy. Once you've done that, open up Corel and paste it in there.
It may also be that the photo you are trying to import is not a JPEG, so Corel might not be recognizing it.
Jan 06, 2011 | Corel Painter Essentials 4 for PC, Mac...
Changing resolution in eps options of Adobe Illustrator C3 (mac)
Unfortunately I do not have the answer, but I do have a recommendation for what I did. I exported the file as a jpeg. This allows you to change the resolution there. Hope this helps.
Mar 23, 2009 | Apple Computers & Internet
Corel-DRAW 12 UNABLE TO EMBED (COLOR) JPG ONTO COLOR BACKGROUND
Right click the graphic and choose the image tools and you wil find an option for color and one for B&W. Play with those to find the problem. That should solve it
Michael
Feb 26, 2009 | Corel WordPerfect Office 12 Standard...
Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
How to get glowing effect in coreldraw
To create a glow: make a copy of your image you want to glow. paste to the side or original. select original. Convert to Bitmap, then use Gaussian blur, select pixel width of blur, preview it, then apply it when it look good. Put your copied image on top of the blurred image, bringing the copied image TO FRONT. voila NOTE change color of image to be bit-mapped BEFORE you convert to bitmap for a COLORED Glow
Dec 19, 2008 | Computers & Internet
Coreldraw (Doubt)
Hi shivshankara,
My name is DennisGladx and I'm Glad to be of assistance.
I have ver 13 but I still have my ownwrs manual to ver 8 and I would direct you to page 652.
If you don't have the manual here are the steps.
1) Left click FILE, Publish to internet.
2) Left click INTERNET DIALOG BUTTON.
3) In the Publish to internet dialog box, enable the HTML button.
4) Choose the folder in which you want to save your published HTML document from the HTML folder list box.
5) type the name of the folder in which you want to save the bitmaps in from your document in the image folder box. (the image folder is a sub folder of the HTML folder.
6) Click export all pages.
Good luck
Glad to be of assistance - please rate the solution - I can learn from your rating. Thank you
Oct 22, 2008 | Corel Draw 8
Image quality in MS Word
JPEG is a raster image. Every pixel is identified to the computer.
MS Word is resizing the picture to make it fit. When it does this it causes pixels to disappear. This is why you will get blocky images and or unreadable text.
The Solution is
Re size the image and bump the dpi to at least 300. This will add enough pixels to where you won't notice the stair step.
The professional way to do it is with Vector images. This is difficult to do if you are using a photograph. You will need to plot the image out (basically re draw it with lines and bucket fills)
Hope this helps you.
May 29, 2008 | Corel Draw 8
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Images
if you want to import any image, it has to be saved with a transparent background, like a (.gif or .png) image.. for example if you have an image i.e plane.jpeg you need to open it in an image editing software like adobe photoshop and delete the background save the image as plane.png and import the plane.png to flash. You can edit the picture in flash also to remove the background.. but the process is not easy and its time consuming. so try that workaround like i said before let us know if it worked.
Oct 02, 2007 | Macromedia Flash MX
Corel AE CorelDRAW Graphics Suite 12 for PC Logo
181 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
