Question about Refrigerators
Fridgidaire ice auger runs continuously
I just replaced the water dispense leaver in my Frigidaire FRS26HF7BW1 side by side. When I reassembled the dispenser and plugged in the switch cable on the front panel the ice dispenser came on and wouldn't shut off. I checked to see if this was a short in the ice dispenser switch. Even with the ice dispenser switch disconnected it the auger motor still runs all the time. Is there some special reset sequence for the boards or is one of the boards shorted? Please help, thanks.
  • Anonymous Dec 30, 2008
    Same thing happened to me, but with model: PLHS69EESS1. I was fixing the water hose that had popped out of position, which was causing water to come out of every opening in the dispenser and was leaking all over the front door of the fridge onto the floor. When I reassembled the dispenser and plugged in the electronic strip, the ice maker started running and would not shut off. I have it unattached at the moment in order to keep it from running. Does anyone have a solution?
  • 473 Answers
SOURCE: shorted control board dispenser
Look and see if the door for the ice chute is closing all the way. This model is bad about that door breaking. If it doesn't shut properly then warm air getting in will cause this condensation. Will also cause ice in bucket to melt and water can leak onto these parts. If it isn't obviously hanging open then shine a flash light from the inside down the chute and see if any light comes thru to the outside. Maytag has a chute door kit that you can find on Their part # is AP3140440. Let me know if this helps or we need to go further.
Posted on Oct 10, 2007
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
  • 725 Answers
SOURCE: Ice dispenser not dispensing
With your power going off your problem sounds like a dispenser control can check for power at the auger motor
38 5304430812 A B C Power Board
38A# 5304421617 A B C Switch-micro,single pole ,double throw
38C 5304430991 A B C Board-control
I would remove the dispencer cover and check the boards for burn marks
hope it helps
Posted on Jul 25, 2008
SOURCE: Ice tray auger will not turn on to eject ice.
Buy Whirlpool
Posted on Jan 14, 2009
Have a Side by Side Frigidaire Ice MAKER and water is OK, Ice Dispenser thru the door just stopped working. I bench tested both the solenoid and the auger motor with 120Vac and both work fine.
Did you check to see if your ice maker is working at all? What are you taking voltage readings at augur motor if it is working? - does not make sense unless you have all sorts of time on your hands. Test water solenoid for ice maker?Need parts? Go to link Search Over 2 1 Million Appliance Parts
Aug 27, 2017 | Frigidaire Washing Machines
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from
Oct 01, 2015 | Frigidaire Refrigerators
I replaced the ribbon cable on my Frigidaire refrigerator and the ice auger for the ice continue to run and water will not dispense when water dispenser is activated. I want to correctly replace the r
Hey friend, thank you for your inquiry!
From my understanding you were replacing the water dispenser on your Frigidaire refrigerator and the ribbon cable disconnected. I would suggest a generic search online for any additional information regarding the ribbon cable. I was unable to locate that information for you. Additionally, if you continue to have problems I would consult with a professional technician for proper attachment of the cable. Best of luck! -Matt
Sep 11, 2014 | Frigidaire Refrigerators
Frigidaire is not dispensing ice
Good Afternoon, thank you for your inquiry!
I see you are having trouble with your Frigidaire refrigerator dispenser not dispensing ice. Do you hear the auger motor running when calling for ice? If you do not, the dispenser may be jammed or the refrigerator has a faulty auger motor. I suggest try clearing any ice that is blocking the ice chute, removing any frozen ice or obstructions, verifying that the water valve or fill tube is not frozen. If any proves to be ineffective contact a professional to move forward accurately.
Best regards! - Z
Jul 11, 2014 | Frigidaire Freezers
Frigidaire Ice Maker M1 SA8868 ice tray not working but have water to the door
Hello - Do you hear the auger motor running when calling for ice? If you do not, the dispenser may be jammed or the refrigerator has a faulty auger motor. I suggest try clearing any ice that is blocking the ice chute, removing any frozen ice or obstructions, verifying that the water valve or fill tube is not frozen. If any proves to be ineffective contact a professional to move forward accurately.
Nov 03, 2012 | Frigidaire GLRS264ZA Side by Side...
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips
Sep 27, 2009 | Refrigerators
I have water in the dispenser but the ice maker doesn't fill
replace the solelnoid for the water dispenser in the back of the fridge
Oct 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
