Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power falure after trying to fix the broken coaxe cable connector on the back of the tv i opened the back and found a connectiong that looked like the same coaxe connection but know tv turns on and off
  • RCA Master
  • 5,138 Answers
Check second ribbon on deflection board if not pluged in right set will make a small squealing sound and will not come on insert correctly set should then come on/.check and make sure all ribbon connectors are in good.
Posted on Oct 17, 2008
We have an older konka tv and the connector where you plug the cable TV in has broken off and cannot be found. We need to buy a new one. We love this TV have had it in the kids room for years.
If you love the tv that much then a broken coax plug is not going to stop you. simply use a standard rca cable to connect your cable box from the tv this works just as good. if you do not have a cable box a vcr would also work as your receiver
May 30, 2011 | Televison & Video
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
How to fix the antenna anolog cable connector that to coax cable connects to on back of TV.
Cut off the bad connector on the end of the coax cable. Go to Radio Shack, Home Depot, etc. and pick up a new twist-on coax connector, or a crimp on version if you have a crimping tool.
Twist the new coax connector on good and tight and you should be good to go.
Mar 30, 2010 | RCA HD52W59 HDTV Projection Television
My 2002 bmw 525i has broken front seats. When I
This is a common BMW problem before giving to a mechanic try looking at the mechanism to see if any bolts are loose or missing,you might find the bracket is broken or torn and needs to be welded or replaced,the job is relatively easy but be carefull because of the SRS system if not sure give it to an expert.
Jul 10, 2009 | BMW 525 Cars & Trucks
The connector at the back of the tv where the cable would be connected broke off during a move. My step dad took the remaining piece out. How can we fix this? Is it a simple thing we can do ourselves?
The coax connector you describe is fairly low-tech, so it can be fixed. You need to open the back of the TV (careful - high voltage in the capacitors) and locate where it came from.
The best thing would be to take some coax cable and solder the appropriate parts (shield and center conductor) to their exposed matches where the break occurred.
You can then run that through the existing hole, put a screw-on F-terminal end on the piece of coax, and a coax coupler on that.
Home Depot, Lowes, Radio Shack, etc. all have these raw parts.
Jun 30, 2009 | JVC AV-27220 TV
Coax receptor broken! Want to replace part.
if you truly need to replace the part then go out to a tv/mechanism store and buy the 12 in receptor to replace.
Mar 12, 2009 | Zenith A19A11D 19" TV
Cable/antenna connector
you can try to get just the coax replacement , otherwise you will have to get the whole tuner, and the number for the tuner is right on the tuner , but just soldering in a new coax connector is cheaper
good luck and thanks!
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
I broke off coax cable on back of 32 inch tv. I can watch dvds with AV cables but not cable TV. How do I connect cable from wall to tv if coax is broken off
This depends on how many available inputs you have on the back of the set. If you have more available you can just hook up the cable box composit (yellow, red, and white cables) if not you will need to replace the rf connector or tuner in the set. let me know if you need more help.
Tim
Sep 11, 2008 | Televison & Video
Slot where cable fits in - Broke
I am assuming that what you are referring to as "metal block" is the tuner assy. and that the "slot/cable receptor" is the chassis mounted 75ohm TV "F" Coax Connector (female). This is easily replaced and the component should be readily available from most electronics part stores.
To perform a DIY and replace this, the TV has to be opened, the metal cover of the tuner pried open, and the F connector replaced and eventually soldered in place.
Incidentally, a nice tutorial on how to go about this is posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 07, 2008 | Samsung TXG2547 25" TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
