Memory ram can i put the 4 gig in one **** and work whit that????
  • 49 Answers
Nope, 1 slot can only accomodate 2gb of ram. and also take NOTE that 4gb can only be read if the windows is running 64bit ,now if the system is running 32bit and there are 4 gb of ram installed on the system . The system will only read 3 or 3.5 gb of ram.
Posted on Oct 12, 2008
Computor is slow
Many of these only came with 4 gigabytes of RAM memory. You need more with Windows 8 and 8.1. You can get another 4 gig of DDR3 Memory and put it in the open memory socket next to the 4 gig you have.
Dec 15, 2013 | Gateway GT5220 PC Desktop
Bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
put it in an open memory slot although its recommended to add it for an even amount of memory (ie. 2, 4, 6, 8) if im not mistaken 4 slots w/ 8Gb max memory
go here: http://www.crucial.com/, and make sure all is compatible, with free memory scanner(it is safe i have used it and got no viruses)
Oct 31, 2012 | Computers & Internet
Ram speed-what does it do
Your PC support up to 4 gig of memory in 4 slots.
DDR 333/400 ram memory of 1 gig each.
So you need to know how much memory your system had.
Probably 2 gig.So the more memory the better will be the speed for run apps in your system.
Read more at http://en.wikipedia.org/wiki/Random-access_memory
Dec 13, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
I am installing a 64-bit OS in my dell optiplex 960 desktop and i want to max out the memory on my PC.What is the maximum memory it can support and what is the best memory i can put in it and what can i...
You have 4 slots and each slot can support 4 gigs so you can have 16 gigs of ram total. I like corsair or Kingston ram the best. And when you are buying ram you want to look at three things. First is the type of ram which your type of ram is ddr2, second is ram speed which is measure in mhz you want the highest mhz you can get and last is latency, which you want the lowest latency you can get :) hope this helps. Visit newegg.com they have great deals its where i buy all my computer parts from :)
Dec 30, 2010 | Dell OPTIPLEX 960S Desktop Computer
I dont know wat sort of ram to choose for this board because i am wanting to put in x6 4 gig ram ddr3 memory modules
running triple channel memory with more than 3 DDR3 1600 sticks installed (4-6) cuts the memory speed in half. you have to run with 3 sticks at a time in triple channel mode or you will see a reduction in ram speeds.
OCZ is making some good 4 gig ram sticks. they have a 12 gig triple channel memory kit with 3x4gig sticks. you could get 2 of these kits and have your 6 sticks- 24 gigs total, but your memory frequencies will be lower- your ram access will be slower.
Oct 28, 2010 | ASUS P6X58DE Desktop Board Intel Chipset...
Umm the info on one of my appliances is wrong and have no ide a how to edit iton this website by the way it's a 3 gig ddr2 about to be a 4 gig apparently that's the max the motherboard will allow even...
If you have a 32 bit version of Windows dont put in 4 gigs. The Motherboard may support it but a 32 Bit version of Windows will only support a total of 4 gigs of ram including the video memory, cache, and pci. If its a 32 bit I normally recommend no more than 3.5 gigs of ram memory. Normally its safer to run 3 gigs. Windows may not run well if you go past that 4 gig point. As far as the appliances problem your refering to I didnt understand what you were asking for.
Hope this helps keep you from having a ram issue.
If you need help with the other question please be more specific. Thanks...
Sep 23, 2009 | Gateway GT5453E Refurbished AMD Desktop...
Is 1 gig of ram enough memory to support vista to run?
Hey there you want to use vista?? lol good luck. You need a min of 2 gigs ram to run vista but should ideally have 4 gigs for good operation. vista is a memory hog. You can change the configuration to use less but still need at least 2 gigs
seth
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
4 gigs of ram on xp 32 bit
Depends on how much memory your motherboard can accomodate. If *********** board can support 4 gig then just plug your ram and it should work.. xp supports up to 4 gig of ram so even if you connect an 8 gig,it will only recognize the 4gig. Hope this help,
May 11, 2008 | Microsoft Windows XP Professional
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
