NetGear WGR614 Wireless Router Logo
Posted on Oct 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Initialisation faillure The Netgear installation procedure in five steps stops at step 3. Some how the wgr614 doesnot see my computer which is a brand new compaq pressario dual core with wireless adapter vista home basic Norton antivirus. In his configuration I manually switched on the adapter but no any reaction. Are there any special things to know Greetings from Rob
Anonymous
Level 3:
Genius:
  • Master 1,913 Answers
  • Posted on Oct 11, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687614
Points
5322
How do I reset my router and connect it to a different computer?
Look for a little hole that reads reset and press it with a little pin, hold it for about 10 seconds
4helpful
How do i reset my netgear wgr614v10 router to manufacturer default setting
Hi there!
Take a paper clip, and insert it into the little reset hole in the back of the router... hold for at least 20 seconds.
username and password: the defaults are admin and password..
Hope this helps
levibit
I purchased a WGR614 Wireless Router and it won't go past step 3 on the installation because it says that my login information is incorrect after identifying it as a static IP address.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
3helpful
Hot to reset the seting to default
reset the router and use the default user/password (check documentation)
Trying to install netgear wgr614 wireless router. instructions indicate to shut off modum. this is not an option for us. how can this be by passed?
im pretty sure you will be fine if you bypass that step, or simply disconnect the modem from your router during that step.
Installation problems
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Problem with initial install
hello!
Step 7: test the Internet connection on both pc
ISP blocking access after new router installed.
hello!
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
ISP blocking my internet connection.
hello!
-- do you know your verizon username and password?
-- have you tried connecting your computer directly to the modem to check if you can get online?
Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
Trying to install router, no success
hello!
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
